zms segfault on ubuntu 13.10 64-bit
Posted: Fri Feb 21, 2014 9:17 pm
This is on a VM, with 2 GB RAM and 2 CPU. 1 IP Camera connected
the following sysctl.conf tweak is in place, tried different values.. no difference
whenever trying to view the camera stream, it dumps this segfault
which afterward leaves you with the following in the logs
been going at this a few days now, any help would be appreciated.
zoneminder 1.26.5-raring amd64
kernel.shmall = 167772160
kernel.shmmax = 536870912
Feb 21 16:10:44 ubuntu zms[2615]: INF [Authenticated user 'admin']
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Got signal 11 (Segmentation fault), crashing]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Signal address is 0x10, from 0x7f6fa9d2e578]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 0: /usr/lib/cgi-bin/nph-zms() [0x470250]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0xfbb0) [0x7f6fa8475bb0]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 2: /usr/lib/x86_64-linux-gnu/libavformat.so.53(avio_write+0x18) [0x7f6fa9d2e578]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 3: /usr/lib/x86_64-linux-gnu/libavformat.so.53(+0xb0132) [0x7f6fa9db2132]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 4: /usr/lib/x86_64-linux-gnu/libavformat.so.53(avformat_write_header+0x2b6) [0x7f6fa9dbc766]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 5: /usr/lib/cgi-bin/nph-zms() [0x4524eb]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 6: /usr/lib/cgi-bin/nph-zms() [0x452b58]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 7: /usr/lib/cgi-bin/nph-zms() [0x44cef5]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 8: /usr/lib/cgi-bin/nph-zms() [0x44e1d3]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 9: /usr/lib/cgi-bin/nph-zms() [0x407642]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 10: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f6fa7114de5]]
Feb 21 16:10:44 ubuntu zms[2615]: ERR [Backtrace 11: /usr/lib/cgi-bin/nph-zms() [0x406709]]
Feb 21 16:10:44 ubuntu zms[2615]: INF [Backtrace complete, please execute the following command for more information]
Feb 21 16:10:44 ubuntu zms[2615]: INF [addr2line -e /usr/lib/cgi-bin/nph-zms 0x470250 0x7f6fa8475bb0 0x7f6fa9d2e578 0x7f6fa9db2132 0x7f6fa9dbc766 0x4524eb 0x452b58 0x44cef5 0x44e1d3 0x407642 0x7f6fa7114de5 0x406709]
Feb 21 16:10:46 ubuntu web_php[2607]: ERR [socket_sendto( /tmp/zm/zms-231077s.sock ) failed: Connection refused]
Feb 21 16:10:46 ubuntu web_php[2607]: ERR [getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-231077s.sock ) failed: Connection refused - checkStreamForErrors()]
