scheduler start/stop record: is it possible?
cybermod
Post by cybermod »
for example, i need to star record from 20.00 PM to 8.00 AM, is it possibile?
basketcase
Re: scheduler start/stop record: is it possible?
Post by basketcase »
You sure can, I do this at home.
I'll steal whats written on the FAQ: http://www.zoneminder.com/wiki/index.php/FAQ
How can I get ZM to do different things at different times of day or week?
Now you can switch between these two states by selecting them from the same dialog you saved them, or from the command line from issue the command zmpkg.pl <run state>, for example zmpkg.pl Daytime.
The final step you need to take, is scheduling the time the changes take effect. For this you can use cron. A simple entry to change to the Daylight state at at 8am and to the nighttime state at 8pm would be as follows,
0 8 * * * root /usr/local/bin/zmpkg.pl Daytime
0 20 * * * root /usr/local/bin/zmpkg.pl Nighttime
Hope that helps!
cybermod
Post by cybermod »
great, tnx so much for your reply bascketcase!
