Analyze sub-stream, Record Main stream
Posted: Wed Feb 26, 2014 10:54 pm
Hi guys,
Haven't posted in quite a while... started with 1.24, went to 1.25 virtual machine, and recently installed 1.26.5.. I'm currently running running an 8 core / 16 gb Centos server with zm running 4 cores & 4 gb's in an Ubuntu KVM guest. New version seems to run much smoother than older ones... No on to the topic:
I recently installed a Dahua IPC-HFW2100 720p ip camera. I'm considering adding more of these or even going with their 1080p version. Right now, I'm seeing maybe 10-15% of a core for zma & zmc for this camera... My older 640x480 cams run much less. If add a 1080p cam, I could see the core usage go up much higher.. though I haven't done any testing or research. But this got me thinking... all these newer ip cams seem to run a main stream (e.g., 1080p) and a sub-stream at a lower resolution (e.g., D1)... My question is would it make sense to to use both streams? The sub-stream for analysis and record the actual event based on the main stream? It would seem there would be some processing savings here at the expense of some bandwidth maybe (two streams).
Can we do this today? Is this something that would make sense moving forward as camera resolutions increase? Or.. should we just grow our processing power as we grow our resolution??
Any thoughts?
Any thoughts?
