I'm trying to change the stream format from "mjpg" to "mpeg". When i change the "WEB_L_STREAM_METHOD" to "mpeg", zoneminder crashes.
2014-03-03 18:10:51.003317 zms 5430 INF addr2line -e /usr/lib/cgi-bin/nph-zms 0x80b0bf0 0xb774940c 0xb7749424 0xb622f1df 0xb6232825 0x805a760 0x80944c3 0x808f436 0x80906ec 0x804da24 0xb621a4d3 0x804ca01 zm_signal.cpp 104
2014-03-03 18:10:50.980118 zms 5430 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 103
2014-03-03 18:10:50.978034 zms 5430 ERR Backtrace 11: /usr/lib/cgi-bin/nph-zms() [0x804ca01] zm_signal.cpp 96
2014-03-03 18:10:50.970791 zms 5430 ERR Backtrace 10: /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0xb621a4d3] zm_signal.cpp 96
2014-03-03 18:10:50.963501 zms 5430 ERR Backtrace 9: /usr/lib/cgi-bin/nph-zms() [0x804da24] zm_signal.cpp 96
2014-03-03 18:10:50.958440 zms 5430 ERR Backtrace 8: /usr/lib/cgi-bin/nph-zms() [0x80906ec] zm_signal.cpp 96
2014-03-03 18:10:50.954919 zms 5430 ERR Backtrace 7: /usr/lib/cgi-bin/nph-zms() [0x808f436] zm_signal.cpp 96
2014-03-03 18:10:50.953023 zms 5430 ERR Backtrace 6: /usr/lib/cgi-bin/nph-zms() [0x80944c3] zm_signal.cpp 96
2014-03-03 18:10:50.945841 zms 5430 ERR Backtrace 5: /usr/lib/cgi-bin/nph-zms() [0x805a760] zm_signal.cpp 96
2014-03-03 18:10:50.922625 zms 5430 ERR Backtrace 4: /lib/i386-linux-gnu/libc.so.6(abort+0x175) [0xb6232825] zm_signal.cpp 96
2014-03-03 18:10:50.916875 zms 5430 ERR Backtrace 3: /lib/i386-linux-gnu/libc.so.6(gsignal+0x4f) [0xb622f1df] zm_signal.cpp 96
2014-03-03 18:10:50.895282 zms 5430 ERR Backtrace 2: [0xb7749424] zm_signal.cpp 96
2014-03-03 18:10:50.893408 zms 5430 ERR Backtrace 1: [0xb774940c] zm_signal.cpp 96
2014-03-03 18:10:50.875400 zms 5430 ERR Backtrace 0: /usr/lib/cgi-bin/nph-zms() [0x80b0bf0] zm_signal.cpp 96
2014-03-03 18:10:50.862141 zms 5430 ERR Signal address is 0x1536, from 0xb7749424 zm_signal.cpp 75
2014-03-03 18:10:50.859161 zms 5430 ERR Got signal 6 (Aborted), crashing zm_signal.cpp 53
2014-03-03 18:10:50.851005 zms 5430 PNC Could not open codec zm_mpeg.cpp 251
2014-03-03 18:10:50.811059 zms 5430 WAR Could not deduce output format from file extension: using mpeg zm_mpeg.cpp 75
2014-03-03 18:10:09.999573 zma_m1 5361 INF foscam_ubuntu: 1000 - Processing at 8.62 fps zm_monitor.cpp 1147
2014-03-03 18:10:09.802761 zmc_m1 5356 INF foscam_ubuntu: 1000 - Capturing at 8.62 fps zm_monitor.cpp 2783
