Hey
I am using fedora 20, and its all well configured.
Its almost all working but the camera.
Camera turns on but gives no image, i think the problem is not in the zoneminder, but its in the console.
Unfortunatly, logs are not very helpful becouse i get no errors from them.
Logs just say that camera is capturing and processing, but it shows no image.
Can some1 help me pls?
Camera shows no image (but its turned on)
Re: Camera shows no image (but its turned on)
anyone can help me?
thanks in advance
thanks in advance
More information please:
How is the camera configured - a dump of the 'general' and 'source' tabs from the monitor window would be helpful.
There is an excellent (but long) troubleshooting section on the Wiki - http://www.zoneminder.com/wiki/index.ph ... leshooting - have you followed any of the steps here?
I guess the best place to start is determining if your camera is actually working as expected - if using V4L (direct connection to a capture card) you can follow the steps for xawtv or zmu to gather more information. If it's a remote (IP/network based camera) then can you use your connection information from the source tab to connect using a web browser?
I have a similar problem with one of my 2 cameras, it may require lots of troubleshooting to get a stable installation.
Good luck - post the additional information and we'll see if we can get you working.
