can not view recorded events
kronos.gaia
Post by kronos.gaia »
i am pretty new in zoneminder and with Linux, so pls excuse maybe trivial questions.
i have installed zoneminder 1.26 on Ubuntu 12.04. Running a Instar 2905 camera.
i have the following issues:
* if i want to view an recorded event i can see the first image; then the screen turns black and i get the message "time to next event...." the countdown starts, goes to 0 and starts again a few times.
this is the log i have captured:
2014-03-19 08:49:08.745533 zms 27527 DB1 Monitor Outdoor1 LBF = '%N - %d/%m/%y %H:%M:%S', LBX = 0, LBY = 0 zm_monitor.cpp 513
2014-03-19 08:49:08.745069 zms 27527 DB1 Monitor Outdoor1 has function 3 zm_monitor.cpp 512
2014-03-19 08:49:08.744091 zms 27527 ERR Can't open events/Outdoor1/diag-0-poly.jpg: No such file or directory zm_image.cpp 797
2014-03-19 08:49:08.732364 zms 27527 DB1 Initialised zone 0/All - 1 - 640x480 - Rgb:0000ff, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0 zm_zone.cpp 50
2014-03-19 08:49:08.731811 zms 27527 DB1 Unable to map file /dev/shm/zm.mmap.1 (15361760 bytes) to locked memory, trying unlocked zm_monitor.cpp 405
2014-03-19 08:49:08.731293 zms 27527 DB1 mem.size=15361760 zm_monitor.cpp 381
2014-03-19 08:49:08.730296 zms 27527 DB1 monitor purpose=0 zm_monitor.cpp 373
2014-03-19 08:49:08.729671 zms 27527 DB1 Got 1 monitors zm_monitor.cpp 2436
2014-03-19 08:49:08.726335 zms 27527 DB1 Query: source=event&mode=jpeg&event=774&frame=1&scale=100&rate=100&maxfps=5&replay=single&connkey=335170&rand=1395215348 zms.cpp 102
2014-03-19 08:49:08.725324 zms 27527 DB1 Detected a x86\x86-64 processor with SSSE3 zm_utils.cpp 171
2014-03-19 08:49:08.715928 zms 27527 DB1 LogOpts: level=DB1/DB1, screen=OFF, database=DB9, logfile=DB1->/tmp/zm/zm_debug.log.27527, syslog=ERR zm_logger.cpp 230
it was working a few days before, but it seems i have screwed things up.
general i think i might have issues with my security settings because i can not delete events out of the application (using the little "x" beside the event)
any help would be very appreciated.
thanks a lot
david
