Zoneminder won´t start
Posted: Mon Mar 24, 2014 3:27 pm
hello everyone
This is the error:
Can someone solve this problem?
thanks in advance
This is the error:
[root@localhost ZoneMinder-1.25.0]# systemctl status zoneminder.service
zoneminder.service - Video security and surveillance system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; disabled)
Active: failed (Result: exit-code) since Seg 2014-03-24 15:24:08 WET; 9s ago
Process: 5870 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=2)
Mar 24 15:24:08 localhost.lan zmpkg.pl[5870]: Bareword "ZM_PATH_LOGS" not allowed whil...3.
Mar 24 15:24:08 localhost.lan zmpkg.pl[5870]: BEGIN not safe after errors--compilation...8.
Mar 24 15:24:08 localhost.lan zmpkg.pl[5870]: Compilation failed in require at /usr/sh...4.
Mar 24 15:24:08 localhost.lan systemd[1]: zoneminder.service: control process exited, ...=2
Mar 24 15:24:08 localhost.lan systemd[1]: Failed to start Video security and surveilla...m.
Mar 24 15:24:08 localhost.lan systemd[1]: Unit zoneminder.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
thanks in advance
