New Event gets stuck recording until i stop the zm service
scooter217
Post by scooter217 »
RESOLVED: Setting the Alarm Reference Image Blend did stop the long events. All is running well now!!
EDIT: I didnt have Alarm Reference Image Blend %ge set to anything. I set this to 12.5% to see if this clears up the issue. I will monitor it over night to see if the issue re-occurs.
Ubuntu 12.04 Server 64 Bit
Zoneminder 1.27
1 camera recording at 10 FPS
Intel core duo with 12GB of RAM
this is a new install so its been up maybe a day. One thing I noticed today is that I will get a New Event that will go on forever. This is the second time this occurred today. If I restart the zoneminder service, the event will obviously stop and events will record normally again. I have Alarm Reference Image Blend set to 12.5% outdoor. I have debugging level set to 2. I havent noticed anything in the logs. I am not sure what level I should turn debugging up to, to figure out why the events are getting stuck. I have Modect on for the monitor by the way.
Checking the logs is showing that alarm pixels are picking up something but when i am looking at the monitor, there is nothing going on on the monitor. Its almost like something is stuck. My min alarm pixel for the monitor is 10000. I am certain if i stop and start the service all will be back to normal.
03/30/14 18:51:30.548004 zma_m1[5068].DB1-zm_event.cpp/558 [Writing capture frame 6103]
03/30/14 18:51:30.580139 zma_m1[5068].DB1-zm_event.cpp/570 [Adding frame 6103 to DB]
03/30/14 18:51:30.679787 zma_m1[5068].DB1-zm_zone.cpp/785 [Street: Pixel Diff: 50, Alarm Pixels: 35229, Filter Pixels: 0, Blob Pixels: 0, Blobs: 0, Score: 6]
03/30/14 18:51:30.739884 zma_m1[5068].DB1-zm_event.cpp/558 [Writing capture frame 6104]
03/30/14 18:51:30.766825 zma_m1[5068].DB1-zm_event.cpp/570 [Adding frame 6104 to DB]
03/30/14 18:51:30.866095 zma_m1[5068].DB1-zm_zone.cpp/785 [Street: Pixel Diff: 50, Alarm Pixels: 35234, Filter Pixels: 0, Blob Pixels: 0, Blobs: 0, Score: 6]
03/30/14 18:51:30.923535 zma_m1[5068].DB1-zm_event.cpp/558 [Writing capture frame 6105]
03/30/14 18:51:30.950082 zma_m1[5068].DB1-zm_event.cpp/570 [Adding frame 6105 to DB]
03/30/14 18:51:31.041168 zma_m1[5068].DB1-zm_zone.cpp/785 [Street: Pixel Diff: 51, Alarm Pixels: 34593, Filter Pixels: 0, Blob Pixels: 0, Blobs: 0, Score: 6]
03/30/14 18:51:31.098800 zma_m1[5068].DB1-zm_event.cpp/558 [Writing capture frame 6106]
03/30/14 18:51:31.125363 zma_m1[5068].DB1-zm_event.cpp/570 [Adding frame 6106 to DB]
03/30/14 18:51:31.216557 zma_m1[5068].DB1-zm_zone.cpp/785 [Street: Pixel Diff: 51, Alarm Pixels: 34263, Filter Pixels: 0, Blob Pixels: 0, Blobs: 0, Score: 6]
03/30/14 18:51:31.273977 zma_m1[5068].DB1-zm_event.cpp/558 [Writing capture frame 6107]
03/30/14 18:51:31.308177 zma_m1[5068].DB1-zm_event.cpp/570 [Adding frame 6107 to DB]
03/30/14 18:51:31.400148 zma_m1[5068].DB1-zm_zone.cpp/785 [Street: Pixel Diff: 50, Alarm Pixels: 35083, Filter Pixels: 0, Blob Pixels: 0, Blobs: 0, Score: 6]
03/30/14 18:51:31.457508 zma_m1[5068].DB1-zm_event.cpp/558 [Writing capture frame 6108]
03/30/14 18:51:31.484763 zma_m1[5068].DB1-zm_event.cpp/570 [Adding frame 6108 to DB]
