fixinfo() undefined error
After downloading zonemider-master from GitHub and building on a Puppy Linux UPUP 3.9.9.2 OS and attempting to add a monitor I received a function not defined error for fixinfo(). I found the line in the code and commented it out and adding a monitor worked. I just built a zoneminder 1.27 from the github master source a few days ago and the code is slightly different and runs well. This new version was an attempt to see if I could get zoneminder to run in an XAMPP stack. Which it does with some tweaking. Just wondering if this function has been recently added? Does the installation using XAMPP cause the error?
