Page 1 of 2
Start up problems on F20_64
Posted: Fri Apr 04, 2014 7:34 pm
by jHeron
I have installed all the prerequisites and the f20_64 RPM from here
http://www.zoneminder.com/forums/viewto ... =9&t=21400
as well as downgraded gnutls. I then followed the instructions for setting up HTTPD and mysql (MariaDb in my case since I already have Mythtv running with it).
When I run
I don t get any errors but it doesn't start. In the zm log from the console I get these errors:
2014-04-04 15:29:30.837390 zmpkg 3633 ERR Unable to run "/usr/bin/zmdc.pl startup", output is "Starting server" zmpkg.pl
2014-04-04 15:29:30.796900 zmdc 3641 FAT Can't connect: No such file or directory zmdc.pl
2014-04-04 15:29:22.868080 zmdc 3644 FAT Can't bind: No such file or directory zmdc.pl
2014-04-04 15:29:20.796600 zmdc 3644 INF Server starting at 14/04/04 15:29:20 zmdc.pl
2014-04-04 15:29:20.641300 zmpkg 3633 INF Command: start zmpkg.pl
I checked and zmdc.pl is where it should be in /usr/bin.
Any suggestion on what might be the problem here?
I have spent the last couple hours googling arouind without much joy...
Any help would be appreciated!
Cheers,
Jon
Re: Start up problems on F20_64
Posted: Fri Apr 04, 2014 8:01 pm
by knight-of-ni
Either selinux is blocking zoneminder (very common) or there is another reason why zoneminder cannot create a socket.
Verify the folder zoneminder is using for sockets (its in options) exists and then verify that apache can write to it.
Posted: Fri Apr 04, 2014 8:45 pm
by jHeron
Thanks for the response!
selinux is disabled altogether. I checked under options->Paths->PATH_SOCKS and its set to /tmp/zm/
That folder didnt exist so I created it and did a
to it and still no joy...
I am not sure how to make sure apache can write to it?
Excuse my linux ignorance!
I will research now how to make sure apache can write to it...
[Edit]
I tried
and still no joy...
[/edit]
Cheers,
Jon
Posted: Sat Apr 05, 2014 3:48 pm
by jHeron
I am trying to wrap my head around what the permissions should be.
For example when I ls -l on /var/www I see that root has ownership, is that correct or should it be owned by apache or www-data?
I am confused... As usual...
[jon@localhost-localdomain ~]$ ls -l /var/www
total 8
drwxrwxrwx. 2 root root 4096 Mar 28 07:10 cgi-bin
drwxrwxrwx. 2 root root 4096 Mar 28 07:10 html
I also notice that the html and cgi-bin folders are empty and dont contain a zm folder.
Am I barking up the wrong tree here or what?
Cheers,
Jon
Posted: Sat Apr 05, 2014 4:17 pm
by knight-of-ni
The RPM will install all the files and permissions necessary for a working system.
This has been tested on a clean system and is known to work fine.
My recommendation is to set everything back to its defaults. Undo the changes you have made in options, undo the virtual host settings and any other apache changes you have made (let's stick with the basic for now), and undo anything else you may have changed.
PATH_SOCKS should point to /var/lib/zoneminder/sock
It works. Don't change this.
Nothing should live under /var/www. This is by design and is why the owner is root. Instead, web applications are aliased in from a subfolder under /usr/share. This is the current way of doing things. If you look under /usr/share/zoneminder you will the web files and that they ahve the proper permission.
Apache is the username you should look for when checking permissions on CentOS. www-data comes from the devian/ubuntu world and will not (should not) exist.
Also, make sure you don't have anything laying around from a previous attempt at installing zoneminder ....most especially if you tried to install from source previously.... you have to get rid of everything with a "make uninstall" first before installing an rpm package.
Once we get your system back to a known good state then let's get it working. After that, then let's slowly customize it (e.g. apache virtualhost) and verify every step along the way.
Posted: Sat Apr 05, 2014 4:21 pm
by jHeron
FWIW I also noticed that the installer is looking for the readme with the version number appended onto zoneminder, like this:
Running transaction
Installing : zoneminder-1.27.0-1.fc20.x86_64 1/1
Adding user apache to group video
Adding user apache to group dialout
/usr/share/doc/zoneminder-1.27.0/README.Fedora: No such file or directory
Verifying : zoneminder-1.27.0-1.fc20.x86_64 1/1
Installed:
zoneminder.x86_64 0:1.27.0-1.fc20
Complete!
I can see that the readme is there but its under just zoneminder.
This likely has nothing to do with my problem but I thought I would report it just in case...
Cheers,
Jon
Posted: Sat Apr 05, 2014 4:30 pm
by jHeron
OK, thanks!
I have not changed anything in options, by default it had /tmp/zm for PATH_socks. Shall I change it to /var/lib/zoneminder/sock?
I have surly screwed this all up from previous attempts to install from source as well as trying to install the 1.25 RPM from the fedora repo (I just stumbled upon the users submission part of the forum yesterday where I saw your generous RPMS)...
FWIW I have always done a make uninstall or sudo yum remove action before starting with a new attempt...
So I guess at this point I will remove all packages and folders that are related that I can find and start over with a fresh install of your generously made RPM?
Thanks for your help and dedication!
Jon
Posted: Sat Apr 05, 2014 4:36 pm
by knight-of-ni
jHeron wrote:OK, thanks!
Jon
The fact that your PATH_SOCKS wasn't pointing to the value it should have been pointing to, I think reveals a vital clue as to what the overall problem may be.
Are you using existing database from another system or a previous non-rpm installation of zoneminder?
I think that is what the issue is.
Posted: Sat Apr 05, 2014 4:57 pm
by jHeron
No, though I have set up DB's from non RPM sources on this same machine I never got them working and just dropped and then re created the DB on subsequent attempts to get it running again... The current DB looks correct and is listed as 1.27, at least to my rookie eyes...
I tried changing the SOCKS path to what you said should be default and zm is now running!
Though I am still getting errors I feel I am getting closer now...
2014-04-05 12:49:30.162090 zmwatch 2804 ERR Memory map file '/dev/shm/zm.mmap.1' should have been 896 but was instead 0 zmwatch.pl
2014-04-05 12:49:30.135310 zmwatch 2804 ERR Memory map file '/dev/shm/zm.mmap.1' should have been 896 but was instead 0 zmwatch.pl
2014-04-05 12:49:26.112240 zmdc 2745 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2014-04-05 12:49:26.090468 undef 3012 ERR Attempt to fetch integer value for ZM_OPT_ADAPTIVE_SKIP, actual type is boolean. Try running 'zmupdate.pl -f' to reload config. /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_config.cpp 185
2014-04-05 12:49:26.028720 zmdc 3012 INF 'zma -m 1' started at 14/04/05 12:49:26 zmdc.pl
2014-04-05 12:49:26.028710 zmdc 2745 INF 'zma -m 1' starting at 14/04/05 12:49:26, pid = 3012 zmdc.pl
2014-04-05 12:49:26.003890 zmdc 2745 INF Starting pending process, zma -m 1
Shall I still proceed to remove anything related that I can and start fresh or do you think I should start troubleshooting the now running zm?
Thanks for you support!
Cheers,
Jon
Posted: Sat Apr 05, 2014 5:03 pm
by jHeron
Ok, I ran the zmupdate.pl -f as suggested in the log and it now seems to be running fine with no errors in the log!!
I am going to try to get a camera working now... Will post an update if I get it all going.
Thanks again!
Cheers,
Jon
Posted: Sat Apr 05, 2014 5:36 pm
by jHeron
OK I got a camera setup and everything is green
I am having an issue with seeing the stream though:
2014-04-05 13:30:04.162286 web_php 2902 ERR socket_sendto( /var/lib/zoneminder/sock/zms-243717s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php
This sounds alot like an issue I had last year with f18 and 1.25. I think it was a permissions problem.
I am going to research it now...
Cheers,
Jon
Posted: Sat Apr 05, 2014 5:49 pm
by knight-of-ni
Glad the system seems to be running.
The underlying issue here is that the system was not in a clean state at the time you chose to install the RPM.
However, if you continue to have issues, I would recommend you start over after making sure all zoneminder related files & databases have been purged. Then follow the installation steps in README.Fedora.
The most common reason for socket_sendto errors is an incorrect Apache config. The README has details on an an issue with overlapping scriptaliases that you should read if you have not already.
Posted: Sat Apr 05, 2014 6:42 pm
by jHeron
"Bring out yer dead.....Bring out yer dead...
I'm not dead yet... actually I'm feeling better..
Thunk!!"
Well its recording events, I can edit the zone images and can browse the stills, just the live video is failing with the socket error mentioned above.
I read the readme and made the edits as suggested with no joy.
Here are my files if its of any use, I tried these and also where I comment out the allias in the httpd.conf file altogether.
httpd.conf
zoneminder.conf
Alias /zm "/usr/share/zoneminder/www"
<Directory "/usr/share/zoneminder/www">
Options -Indexes +MultiViews +FollowSymLinks
AllowOverride All
<IfModule mod_authz_core.c>
# Apache 2.4
Require all granted
</IfModule>
<IfModule !mod_authz_core.c>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
# The code unfortunately uses short tags in many places
php_value short_open_tag 1
</Directory>
ScriptAlias /cgi-bin/zm "/usr/libexec/zoneminder/cgi-bin"
<Directory "/usr/libexec/zoneminder/cgi-bin">
AllowOverride All
Options ExecCGI
# Apache 2.4
Require all granted
</IfModule>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
I will keep plugging away...
Cheers,
Jon
Posted: Sun Apr 06, 2014 12:44 pm
by knight-of-ni
Make sure PATH_ZMS = /cgi-bin/zm/nph-zms
Posted: Sun Apr 06, 2014 1:15 pm
by jHeron
I cant thank you enough!
Its working like a charm now, that was it.
The path that was in mine was /cgi-bin/nph-zms
Cheers,
Jon
