RE: Raspberry Pi Webcam in Zoneminder?
motion2082
Post by motion2082 »
Hey guys,
I have a RPi at home running "Motion". I can get a webstream of my webcam in my browser on 192.168.1.xx:8585
But when I add it to zoneminder all I get is a blank jpeg placeholder with no image.
Has anyone been able to get this working on their setup?
linuxsense
Re: RE: Raspberry Pi Webcam in Zoneminder?
Post by linuxsense »
I am not familiar with Motion. What protocol is that URL providing? A good way to test is to use VLC and find a method to view it, much quicker than changing ZM settings over and over looking for success.
motion2082
linuxsense wrote:I am not familiar with Motion. What protocol is that URL providing? A good way to test is to use VLC and find a method to view it, much quicker than changing ZM settings over and over looking for success.
"Motion" is great if you want a RPi+Webcam out of the box that Motion Detects. However if you want to use a 3rd party program like ZM then the RPi doubles up on Motion Detection which is not what I want to happen.
I have googled RPi + Webcam and everyones tutorials says install "Motion". I don't actually need the "Motion" function on the RPi. Not sure if I can edit the /etc/motion/motion.conf to turn this functionallity off.
Alternately I would be happy with a Webcam streamer that broadcasts a videostream on my IP address.
On a side note, ZM can pick up the "Motion" webcam on IP address using 192.68.x.x:8081/video.cgi however the RPi is working overtime to maintain 1280x720 @ 3MP and send information to ZM so you get too many dropped frames.
have you tried to stream the RPi webcam with FFserver and FFmpeg and then capture on a machine running ZoneMinder. I have read that zoneminder has been sucessfully installed on Raspberry Pi. Then zoneminder was the streamer remote for the second ZoneMinder as master controller.
motion2082
rockedge wrote:have you tried to stream the RPi webcam with FFserver and FFmpeg .
Trying to work this out atm. Does motion run ffserver at the same time?
Here is part of my ffserver.conf , not sure if im doing it right
# Multipart JPEG
<Stream test.mjpg>
Feed feed1.ffm
Format mpjpeg
VideoFrameRate 2
VideoIntraOnly
NoAudio
Strict -1
</Stream>
#Single JPEG
<Stream test.jpg>
Feed feed2.ffm
Format jpeg
VideoFrameRate 2
VideoIntraOnly
VideoSize 352x240
NoAudio
Strict -1
</Stream>
EDIT - 102.168.x.x:8081/test.jpg is now working in Zoneminder when "motion" running on the RPi
