[SOLVED]-Logitech C310 cam on zoneminder 1.25.x-ubuntu12.04
Apanta
Post by Apanta »
Hi all and sorry for my bad english.
Just a little problem.
Installed zoneminder, mysql and apache, under Ubuntu 12.04 lts.
from the web I open normally the zm web interface, but my local webcam is not detected.
these are the webcam data:
this is zm interface:
This is the webcam interface:
The webcam is not running under zoneminder, bu it normallly runs under cheese, skype, Video4Linux Contro Panel and guvcwiew.
how can I solve my problem please.
Thanks in advance.
Apanta
Re: Logithec C310 webcam on zoneminder 1.25.x-ubuntu 12.04
Post by Apanta »
edit:
this is the zm-log:
thanks :mrgreen:
mikb
Post by mikb »
Your logfile (last post) says "Failed to stat /dev/video:" ... can you check that you have used /dev/video0 everywhere you should in the config?
It looks like you might have an errant /dev/video that does not exist, whereas /dev/video0 does.
Apanta
Post by Apanta »
mikb wrote:Your logfile (last post) says "Failed to stat /dev/video:" ... can you check that you have used /dev/video0 everywhere you should in the config?
my camero is the following:
probe camera.png (81.99 KiB) Viewed 4556 times
How can I edit and check my config file?.
please give me istrucyions step by step.
PacoLM
Re: Logitech C310 webcam on zoneminder 1.25.x-ubuntu 12.04
Post by PacoLM »
You need to provide a video format and a valid palette. Try with PAL and UYYYV, I will post the correct config later.
Apanta
Post by Apanta »
PacoLM wrote:You need to provide a video format and a valid palette. Try with PAL and UYYYV, I will post the correct config later.
Ok, adjusted video format on PAL and palette on UYYV and now the camera runs.
Now, how can I find the archive where the events are saved?
How can I modify the destination folder where the events are? (I would like to use a storage hardisk, for zoneminder storage only).
thanks.
PacoLM
Post by PacoLM »
The default location depends on the ZM version and Linux distribution. I would say that the most common is /usr/share/zoneminder/events.
There are many posts talking about changing the default location, and also some entries of the wiki. Please, use the search option of the forum.
Regards,
PacoLM
Apanta
Post by Apanta »
PacoLM wrote:The default location depends on the ZM version and Linux distribution. I would say that the most common is /usr/share/zoneminder/events.
Regards,
PacoLM
Thanks a lot for your patience.
I'll try to find what I need.
