Page 1 of 1
[SOLVED]-Logitech C310 cam on zoneminder 1.25.x-ubuntu12.04
Posted: Sun Apr 13, 2014 8:40 pm
by Apanta
Hi all and sorry for my bad english.
Just a little problem.
Installed zoneminder, mysql and apache, under Ubuntu 12.04 lts.
from the web I open normally the zm web interface, but my local webcam is not detected.
these are the webcam data:
this is zm interface:
This is the webcam interface:
The webcam is not running under zoneminder, bu it normallly runs under cheese, skype, Video4Linux Contro Panel and guvcwiew.
how can I solve my problem please.
Thanks in advance.
Re: Logithec C310 webcam on zoneminder 1.25.x-ubuntu 12.04
Posted: Sun Apr 13, 2014 8:51 pm
by Apanta
edit:
this is the zm-log:
thanks :mrgreen:
Posted: Mon Apr 14, 2014 5:43 pm
by mikb
Your logfile (last post) says "Failed to stat /dev/video:" ... can you check that you have used /dev/video0 everywhere you should in the config?
It looks like you might have an errant /dev/video that does not exist, whereas /dev/video0 does.
Posted: Mon Apr 14, 2014 8:45 pm
by Apanta
mikb wrote:Your logfile (last post) says "Failed to stat /dev/video:" ... can you check that you have used /dev/video0 everywhere you should in the config?
my camero is the following:
probe camera.png (81.99 KiB) Viewed 4550 times
How can I edit and check my config file?.
please give me istrucyions step by step.
Re: Logitech C310 webcam on zoneminder 1.25.x-ubuntu 12.04
Posted: Tue Apr 15, 2014 2:33 pm
by PacoLM
You need to provide a video format and a valid palette. Try with PAL and UYYYV, I will post the correct config later.
Posted: Thu Apr 17, 2014 11:47 am
by Apanta
PacoLM wrote:You need to provide a video format and a valid palette. Try with PAL and UYYYV, I will post the correct config later.
Ok, adjusted video format on PAL and palette on UYYV and now the camera runs.
Now, how can I find the archive where the events are saved?
How can I modify the destination folder where the events are? (I would like to use a storage hardisk, for zoneminder storage only).
thanks.
Posted: Thu Apr 17, 2014 3:26 pm
by PacoLM
The default location depends on the ZM version and Linux distribution. I would say that the most common is /usr/share/zoneminder/events.
There are many posts talking about changing the default location, and also some entries of the wiki. Please, use the search option of the forum.
Regards,
PacoLM
Posted: Fri Apr 18, 2014 9:21 pm
by Apanta
PacoLM wrote:The default location depends on the ZM version and Linux distribution. I would say that the most common is /usr/share/zoneminder/events.
Regards,
PacoLM
Thanks a lot for your patience.
I'll try to find what I need.
