I hope someone can help me with the settings i seem to be missing. I am sure it is something simple. I am trying to link the streams from my dvr into zoneminder. The stream which works in vlc is.
rtsp://192.168.5.18:554/user=admin&password=&channel=1&stream=1;(0-mainstream;1-substream).sdp
I have tried adding this into the remote path in zone minder without any joy, I also took out the port number from this line and added it to the port box when adding the path in zoneminder but still no joy.
Hopefully someone can help me and let me know what I am missing.
I have tried to post image urls but a new user. i ave tried this
remote protocal = rtsp
remote method = rtp/rtsp/httpp
remote hostname = 192.168.5.18
port = 554
remote path = /user=admin&password=&channel=1&stream=1;(0-mainstream;1-substream).sdp
I am getting an error in my log files...
Unable to get RTP Info identifier from response 'RTSP/1.0 200 OK Content-Length: 0 Server: H264DVR 1.0 CSeq: 3 Range: npt=now- Session: 61106210 '
Oh the zoneminder server is running on ubuntu 12.04
rtsp stream works in vlc but not in zoneminder
Re: rtsp stream works in vlc but not in zoneminder
I have upgraded my zonemider to 1.26.5 but still no joy. If a moderator could move my question to the approiate section. Thanks.
I have noticed that with this error "/tmp/zm/zms-625927s.sock failed no such file or directory"
when i look into that particular directory the file that is being created is "zms-625927w.sock"?
You are using source type Ffmpeg?
Yes i am using ffmpeg I did try remote but had the same issues.
My source path for ffmpeg is rtsp://192.168.5.18:554/user=admin&password=&channel=3&stream=0;(0-mainstream).sdp
my zoneminder conf looks like this
I added the ScriptAlias part after googling about but it also made no difference.
The paths are correct but. Also changed ownership in /usr/share/zoneminder to "www-data" and added ww-data to video group, and chmod 777 in temp folder.
The mystery is that the files being created in the temp foder are zm-****w.sock when they should be zm-****s.sock
Alias /zm /usr/share/zoneminder
<Directory /usr/share/zoneminder>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
ScriptAlias /cgi-bin "/usr/share/zoneminder/cgi-bin"
<Directory "/usr/share/zoneminder/cgi-bin">
Options +ExecCGI -MultiViews +SymlinksIfOwnerMatch
AllowOverride All
</Directory>
I think you need to shorten up your input. I suggest: rtsp://admin:password@192.168.5.18:554/mainstream.sdp
You did not state what your device is. Might help us get you working...
You will also need to set the Capture Height and Width based upon the resolution of your camera or device. If your camera is a 720P try 320X180. If it works you can double the size.
