Camera IP not worked in zoneminder but work in xawtv
ricardobarbosams
Post by ricardobarbosams »
Hi all.
I trying configure the zoneminder, but not worked, but via the command xawtv work. follow my configuration
lspci
03:01.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
03:01.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
dmesg
[ 2221.066202] Linux video capture interface: v2.00
[ 2221.071721] bttv: driver version 0.9.19 loaded
[ 2221.071727] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 2221.071796] bttv: Bt8xx card found (0)
[ 2221.071816] bttv: 0: Bt878 (rev 17) at 0000:03:01.0, irq: 16, latency: 64, mmio: 0xfdffe000
[ 2221.073891] bttv: 0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 2221.075829] tveeprom 14-0050: Huh, no eeprom present (err=-6)?
[ 2221.075835] bttv: 0: tuner type unset
[ 2221.076958] bttv: 0: registered device video0
[ 2221.077217] bttv: 0: registered device vbi0
[ 2221.104241] bt878: AUDIO driver version 0.0.0 loaded
Via command xawtv the image on the camera is displayed in the zoneminder works but have not tried various settings but I judge the correct setting is:
Device Path: /dev/video0
Capture Method: Video for Linux version 2
Device Channel: 0
Device Format: NTSC
Capture Palette: YUYV
I was changing the "device Channel" to see if it takes each camera did not work
My camera is simillar to the image below:
I trying various type "device channel", but not worked.
Any idea.
Regards.
