Major motion sensitivity changes after upgrade to 1.27.
Posted: Thu May 01, 2014 2:50 am
First, note that my problem resulted after upgrading from 1.25 to 1.27, so I do not know whether this is related to the 1.27 release or the 1.26 realease.
I had all my cameras, zones and motion detection settings set up and working very reliably for over a year. After upgrading to 1.27, I initially got a weird combination of over-sensitivity and under-sensitivity. Major events were not being detected, but low-light very minor camera shimmer in the mornings would alarm like crazy (I do not know that the pixel shimmer was causing it, but it was the only thing I could think of for what woudl trigger the alarm since there were no motion events).
I wound up having to tweak a bunch of things and got something a bit better, but still have this weird result where a 15 second event is now lasting 4 minutes (no events occur over the last 225 seconds. I've checked all the settings on pre/post event image counts and such and nothing looks to be mis-set.
Has anyone else had similar issues or know of settings that might have changed or whose semantics might have changed that would cause previous ZM settings to be interpreted very differently in 1.27?
