Cameras not showing
Posted: Tue May 27, 2014 10:22 am
Hi I am very new to linux, my first attempt at using it is for the soul purpose of using Zoneminder, I am running Ubuntu 14.04.
I installed a lamp server off a guide I found online, not sure if I may have configured that wrong.
I've tried to troubleshoot various things in apache/php/mysql but couldn't come up with anything.
My problem in zoneminder is cameras are not showing at all, they show broken image file instead. I first tried an IP camera, than I tried a usb webcam. I have a feeling its to do with my configuration (either lamp or zoneminder). My error log has been giving me this error every 10 seconds even when not connected to a camera:
Memory map file '/dev/shm/zm.mmap.3' should have been 896 but was instead 0
If I try to connect to a camera I get these error messages:
Terminating, last frame sent time 1401185870.356359 secs more than maximum of 10.000000
socket_sendto( /tmp/zm/zms-656083s.sock ) failed: No such file or directory
getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-656083s.sock ) failed: No such file or directory - checkStreamForErrors()
I have been working on this all day and I can't handle doing anymore today, I would be so appreciative if someone could help me out with this. Thanks in advance.
