I seem to have a problem enabling playback (streaming) on my install with cambozola.jar in internet explorer 11.
Used to work perfectly on older versions of IE (before IE10); now i am only getting crosses where the images should be when choosing "Montage" or opening a specific camera. Only think that works is if I open "Cycling" and choose "still images"; then image shows.
I had that problem in IE 10 but adding site to intranet settings seemed to solve the problem; which isn't the case anymore :/
Does anyone have an idea of what may be wrong? Where to start looking?
Hope anyone can help me solving this problem which I assume is IE related.
PS I added a screenshot so you can see what happens.
Cambozola problem IE 11
- Untitled.png (241.02 KiB) Viewed 1722 times
