I was able to get the new camera working with ZM by using ffmpeg as the source and rtsp://username:password@xxx.xxx.xxx.xxx//Streaming/Channels/1 for the source path. As I'm learning and reading, though, using ffmpeg instead of http/mjpeg uses a lot more resource intensive so the zmc process for that monitor is using a lot of CPU.
I've tried decreasing the framerate on the camera and the resolution in ZM (the camera will only send 1280x720, 1920x1080, or 2048x1536 in MPEG-4/rtsp mode so I told ZM to use 704x480). The camera also has a bewildering array of settings for video quality, bitrate, etc. but I can't seem to get ffmpeg CPU usage down.
Does anyone else have one of these cameras and happen to know the source path to use mjpeg over http? My Google searching has not been successful (but it was how I found the proper rstp source path in the first place). If not, any other suggestions on how to limit CPU usage?
