cant access zm web interface from another computer
henryco
Post by henryco »
I have installed zm on mageia successfully: everything works fine except the communication with the external world :
I can generate many alerts by moving in front of the camera but:
ftp : nothing is transferred
email : nothing is sent
though i have carefully configured both
and even from another computer on the same LAN (thus there should be no problem with my isp firewall , right?) i'm not able to access the web zm interface: i thought it would work just with
ipadress/zm/ where ipadress is a local LAN adress of the computer where zm is installed
Thank you if someone has an idea of what i did wrong...
Fred
henryco
Re: cant access zm web interface from another computer
Post by henryco »
and there is also a recurrent error in the logs : gettimeofday() ... it's not safe to rely on system time zone setting...
Have no idea where does this come from
henryco
Post by henryco »
Apparently, the machine where zm is installed is not pingable from the other machine on the LAN...(!?) yet i can access the internet from this machine and nmap says that the only open port is 80...
i suspect something in the iptables but it's really for expert...i understand nothing at all of the result of typing: iptables -L
henryco
Post by henryco »
henryco wrote:Apparently, the machine where zm is installed is not pingable from the other machine on the LAN...(!?) yet i can access the internet from this machine and nmap says that the only open port is 80...
OK the remote access problem is solved , the firewall was not configured properly ... i'm going to try again the email and ftp
