Page 1 of 1
Zones missing Zones2.jpg 404 ?
Posted: Mon Jun 23, 2014 5:30 pm
by sleuth
Hello, I'm new to ZoneMinder... but I am a little technically savvy
Background:
I just set up a new build on a new VM using Mint 16 (based on Ubuntu 13.10), assigned all 16 logical cores on a dual quadcore L5520 server with 20GB of ram... Build a git clone of master from source, showing 1.27.1 version. I only have one camera set up right now, Dahua IPC-HFW4300S, supports 1080p @ 30fps or 3m @ 20 fps. I have it set for 1080p @ 30fps in the camera setup, and in the ZoneMinder setup I'm using LibVLC set at 1920x1080 with a 10fps max. I currently have it set on MoDec.
I click on 1 Zone and it pops up and I'm missing any sort of reference picture, getting a 404 on the image:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /zm/images/Zones2.jpg was not found on this server.</p>
<hr>
<address>Apache/2.4.6 (Ubuntu) Server at 192.168.1.32 Port 80</address>
</body></html>
Is this a bug, is there something I need to do for this image to be populated? Otherwise the monitor screens and basic events seem to be working although, it's definitely triggering on a lot of false positives.
Also as an aside, what's the best way to deal with the transition from night mode (IRs turn on) and day mode since this seems to trigger an alert every morning and night.
Re: Zones missing Zones2.jpg 404 ?
Posted: Tue Jun 24, 2014 7:17 pm
by sleuth
hmm any ideas?
I also have in part of my field of view a sidewalk and as it is an overcast day today, the sun keeps going in and out of clouds and it triggers events as it suddenly gets lighter or darker, may take some playing to get this right I think.
Posted: Tue Jun 24, 2014 8:00 pm
by linuxsense
Does /images/ exist in the root of the ZM tree? And if so, does www-data (or whatever apache runs as) have read/write access to it?
Posted: Tue Jun 24, 2014 8:06 pm
by sleuth
That's it... I guess I should have checked that, but the install process should be tweaked to fix this, I didn't create any of these folders:
/usr/share/zoneminder $ ls -la
lrwxrwxrwx 1 root root 28 Jun 20 20:12 images -> /var/cache/zoneminder/images
/usr/share/zoneminder $ cd /var/cache/zoneminder
/var/cache/zoneminder $ ls -la
total 20
drwxr-xr-x 5 www-data www-data 4096 Jun 20 20:14 .
drwxr-xr-x 18 root root 4096 Jun 20 18:55 ..
drwxr-xr-x 3 www-data www-data 4096 Jun 20 21:14 events
drwxr-xr-x 2 root root 4096 Jun 20 20:12 images
drwxr-xr-x 2 root root 4096 Jun 20 20:12 temp
/var/cache/zoneminder $ sudo chown www-data:www-data images
total 20
drwxr-xr-x 2 www-data www-data 4096 Jun 20 20:12 images
Works!
Posted: Tue Jun 24, 2014 8:08 pm
by linuxsense
I think its a recent issue, I ran into it the other day myself.
Posted: Sun Aug 10, 2014 10:41 am
by nikonaum
Make sure you've added "/var/cache/zoneminder" to open_basedir in php.ini and restart apache server.
Mine looks like this: open_basedir = /srv/http/:/home/:/tmp/:/usr/share/pear/:/usr/share/webapps/:/etc/:/srv/http/zoneminder/:/usr/share/cambozola/:/var/cache/zoneminder/:/tmp/zoneminder/:/var/log/zoneminder/
I'm using Arch Linux and installed ZoneMinder 1.27 from AUR repository. I could not export anything in ZoneMinder or even see image in the create Zones function.
Hope this helps you.
Edit: In my case is "/var/cache/zoneminder". This is the parent directory of the images/, events/ and temp/ directories, yours may be different depending on the distro you are using.
Posted: Wed Aug 20, 2014 4:45 am
by iitywygms
linuxsense wrote:I think its a recent issue, I ran into it the other day myself.
How were you able to solve?
Posted: Wed Aug 20, 2014 1:25 pm
by ThomasNovin
I also have this problem on this version:
root@mistik:/var/cache/zoneminder# apt-cache policy zoneminder
zoneminder:
Installed: 1.27.99+1-trusty-SNAPSHOT2014080402
Candidate: 1.27.99+1-trusty-SNAPSHOT2014080402
Version table:
*** 1.27.99+1-trusty-SNAPSHOT2014080402 0
500
http://ppa.launchpad.net/iconnor/zonemi ... er/ubuntu/ trusty/main i386 Packages
100 /var/lib/dpkg/status
1.26.5-1ubuntu3 0
500
http://se.archive.ubuntu.com/ubuntu/ trusty/universe i386 Packages
From the Zoneminder log:
2014-08-20 15:18:09.373809 zmu 18833 ERR Can't open Zones1.jpg: Permission denied zm_image.cpp 797
I was able to fix this by changing so that www-data owns the directory that houses this file.
root:/var/cache/zoneminder# ls -al
total 20
drwxr-xr-x 5 www-data www-data 4096 jul 28 22:06 .
drwxr-xr-x 33 root root 4096 maj 2 11:02 ..
drwxr-xr-x 3 www-data www-data 4096 okt 25 2013 events
drwxr-xr-x 2 root root 4096 jul 26 20:56 images
drwxr-xr-x 2 root root 4096 jul 26 20:56 temp
root:/var/cache/zoneminder# ls -la images/
total 8
drwxr-xr-x 2 root root 4096 jul 26 20:56 .
drwxr-xr-x 5 www-data www-data 4096 jul 28 22:06 ..
root:/var/cache/zoneminder# chown www-data:www-data images
The installer should have fixed this IMHO as I have not changed this myself.
Posted: Wed Aug 20, 2014 2:32 pm
by iitywygms
I wish I could say the same thing.
I have it setup as everyone says it should be.
But I do not get any images to set up zones.
If I delete the images in the zoneminder images directory and go to add a zone, the image is created but it never shows in zoneminder.
kevin@mythbackend:/var/cache/zoneminder$ apt-cache policy zoneminder
zoneminder:
Installed: 1.27.0-precise-2
Candidate: 1.27.0-precise-2
Version table:
*** 1.27.0-precise-2 0
500
http://ppa.launchpad.net/iconnor/zoneminder/ubuntu/ precise/main amd64 Packages
1.25.0-1 0
500
http://mirror.math.ucdavis.edu/ubuntu/ precise/universe amd64 Packages
kevin@mythbackend:/var/cache/zoneminder$ ls -la
total 20
drwxr-xr-x 5 www-data www-data 4096 Aug 19 19:21 .
drwxr-xr-x 22 root root 4096 Aug 19 19:21 ..
drwxrwxrwx 10 www-data www-data 4096 Aug 19 20:36 events
drwxrwxrwx 2 www-data www-data 64 Aug 19 22:08 images
drwxr-xr-x 2 www-data www-data 4096 Apr 30 11:22 temp
