COTIER IPc-631/T13
littlej
COTIER IPc-631/T13
Post by littlej »
Hello, i don't know for sure if this is the right place but anyway...
I have bought this camera, don't mean to make any advertise ( http://www.dx.com/p/cotier-ipc-631-t13- ... 7Rfy_mSxg8 ) but i find it preatty cheap for an ip cammera with 720p resolution.
Anyway i have just set it up here are the settings :
soruce type : libvlc
rtsp://camera_ip:554/live/mpeg4
resolution 1280x720 24bit
also you have to disable authentication in network - mediastream setup
a snapshot in atached file.
please excuse my poor english.
10x
littlej
Re: COTIER IPc-631/T13
Post by littlej »
Just as an update.
Installed this camera for some time now and it's pretty stable so far but the downside is the night vision, wich is totally useless :) and i mean useless :) I have it running outside at a range of ~15m and you cannot see anything :)
arymar
Post by arymar »
Thanks Littlej,
Just to add: in case you need to access the substream on such Cotier, you need to use the following:
rtsp://camera_ip:554/live/mpeg4cif
Hope this may help someone.
Cheers.
Alain
littlej
Post by littlej »
Hi arymar, thanks for the update.
I have updated my cotier firmware using latest version from here : http://www.en.tpsee.com/deviceupdate/95-1.html ( TH38C5/R6_ONVIF_P2P_firmware_V2.5.1.12 ) at least this suits my camera.
Since update i find the stream more stable and available at
main: rtsp://admin:psassword@ipaddress/mpeg4
sub: rtsp://admin:psassword@ipaddress/mpeg4cif
i have attached a snip from zoneminder config for my camera.
littlej
Post by littlej »
update... after some time this is what happens and i have no idea how to solve it for now :(
i am open for suggestions.
thanks
littlej
Post by littlej »
well another update :P
it seems that if i set the camera on CBR ( constant bit rate ) and i frame key at 15 frames and running 15 fps no more pink rubbish on the stream.
all looks good so far.
Adrien
Post by Adrien »
Thanks for the useful information found here.
How did you find out which FW to use ? where can I find the steps do update the FW ?
littlej
Post by littlej »
Hi, i cannot access the camera right now, but if i remember correctly you can check on the camera the hardware revision.
