Dear,
oops
I selected in the option the "mobile" skin...
How to go back to the "web" skin since there is no "option" tab in the mobile skin (to select teh "web" skin)?
Thank for the help
Marc
How to exit the "Mobile" skin
Re: How to exit the "Mobile" skin
Append '?skin=classic' to the URL you use to connect to ZM (without the single quotes, though). Then you can get to the options to change it permanently.
- knight-of-ni
Heh, heh I did that once, but I didn't remember what I did to fix it.
I have got stuck with a similar problem.... Tried the mobile skin once and can log on using my Iphone and see the camera status' etc.
What I can't do now is log on using my laptop with either IE, Chrome or Opera. I'm stuck in a login loop, it just returns me to the login page no matter what skin extensions I append to the URL. Really getting fed up with it now as I need to access the recordings.
I have tried it on the phone with the mobile skin and when clicking on the camera I want to review I get chucked back to a login screen again... aaarrgh!!!
Any suggestions most welcome!
Doug
Doug
