Filter settings template? - Email notify on motion
Hey all. I got ZM running pretty well. I setup postfix and was able to receive emails for previous alarms after playing with the filter settings. What Id like to do is get a filter setup so that any future motion event alarms are emailed to me with a photo. I don't quite understand all the filter options. Is there a doc with generic motion notification settings or can someone just post what options they use to accomplish the same? Thanks in advance
Re: Filter settings template? - Email notify on motion
For instance this is my current attempt to create an email notify filter and it works ok but what are other users doing to tweak their settings?
http://www.zoneminder.com/wiki/index.ph ... ing_Events
You have to set it up in the Email config tab.
Gracias!PacoLM wrote:http://www.zoneminder.com/wiki/index.ph ... ing_Events
De nada!
