Ubuntu 14.04 zm 1.26.4
People good day. Need help.
1. I have partitioned 2 Tb disk into a 2 partitions - windows with ntfs and linux. I can not save events,images to a windows disk.
dev/sda1 mounts to /media/frank/B8FC97AFFC976702/
i have created on windows disk at a root directories zoneminder/events and zoneminder/images
Path to both directories in zm config:
/media/frank/B8FC97AFFC976702/zoneminder/events
/media/frank/B8FC97AFFC976702/zoneminder/images
in logs i see "Filesystem monitor link 'events' does not point to valid monitor directory"
2. In montage view every camera is set up to 1 vertical line. I have read this - http://www.zoneminder.com/forums/viewto ... 21&t=17537 try to use chromium but does not get a result
3. Export video problem.
can not save events to a windows disk, montage view 1 line
Re: can not save events to a windows disk, montage view 1 li
1. In logs i see
"Can't symlink /media/frank/B8FC97AFFC976702/zoneminder/events/2/14/08/08/.3897 -> /media/frank/B8FC97AFFC976702/zoneminder/events/2/14/08/08/11/26/55: Permission denied"
chmod 777 -R /zoneminder does not give a rights to zomeminder to write to this directory and sundirectories
