Page 1 of 1
How adding my ip camera escam qd 500 on RTSP zoneminder
Posted: Mon Aug 18, 2014 1:57 pm
by samquad
Hello Please help me for adding my ip camera escam QD 500
Video codec H264 mpeg 4 AVC, resolution 1280X720 , 22 frame/s
IP 192.168.1.11
port 554
protocole rtsp
Works well with VLC with this Link:
rtsp://192.168.1.11:554/user=admin&password=admin&channel=1&stream=0.sdp?
I tried to set up the camera on zoneminder with this parameter but it does not work
Remote Protocol: RTSP
Remote Method: RTP/RTSP/HTTP
Remote Host Name: 192.168.1.11
Remote Host Port: 554
Remote Host Path: /user=admin&password=admin&channel=1&stream=0.sdp?
Target Colorspace: 24 bit colour
Capture Width: 1280
Capture Height: 720
maximum fps: 5
Please help me to configure the good value
Thank you
Samquad
Re: How adding my ip camera escam qd 500 on RTSP zoneminder
Posted: Thu Aug 21, 2014 7:27 pm
by knight-of-ni
Try using some of the other Source Types such as ffmpeg or libvlc. Those have better compatibility than the one you are trying to use.
Posted: Sat Aug 23, 2014 1:46 pm
by samquad
it's seem impossible to use other source type
Posted: Sat Aug 23, 2014 1:59 pm
by knight-of-ni
samquad wrote:it's seem impossible to use other source type
If you want the camera to work, you need to use either the ffmpeg or libvlc source type.
Can you provide more details as to what the problem may be?
Posted: Sun Aug 24, 2014 7:04 am
by samquad
This is the zoneminder system log response when the ip camera is configured with rtsp
2014-08-24 08:55:03.283924 zmc_m10 22266 FAT Unable to get RTP Info identifier from response 'RTSP/1.0 200 OK Server: H264DVR 1.0 cseq: 3 Range: npt=now- Session: 64492200 ' zm_rtsp.cpp 483
At the same Time, if y stream with vlc, it is working.
Sorry, i don't understand what you say about source type
Posted: Sun Aug 24, 2014 12:37 pm
by knight-of-ni
You are not configuring the camera correctly in zoneminder.
Open up the monitor configuration and change the "Source Type" from "Remote" to "Ffmpeg".
Verify the other fields in the General and Source tabs maintain appropriate values after making this change.
Posted: Sun Aug 24, 2014 5:20 pm
by samquad
my camera is working now!
source type ffmpeg
Source path:
thank you very much knnniggett
Samquad
Posted: Sat Mar 12, 2016 8:23 am
by raspi
just wanted to know if at the end you had everything working fine includind de PTZ functions?
Thanks in advance for you help
Regards
Erix
Posted: Tue Oct 25, 2016 11:16 am
by nea1
hi all,
same question about PTZ for escam.
Can not get it working with ZM 1.30
any advice appreciated
