Shared data not initialised by capture daemon
Posted: Wed Aug 20, 2014 1:35 pm
I think this is a new problem for me, and it does not look like the old classic problem with too low settings on shared memory, found in FAQ etc?
2014-08-20 15:25:30.971068 zmu 19837 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results zm_monitor.cpp 424
Aug 20 15:50:43 stik zms[22402]: INF [Authenticated user 'admin']
Aug 20 15:50:43 stik zms[22402]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Aug 20 15:50:47 stik zms[22402]: INF [Got signal 15 (Terminated), exiting]
Aug 20 15:50:50 stik zms[22006]: INF [Got signal 15 (Terminated), exiting]
Aug 20 15:50:50 stik zms[22006]: ERR [Unable to send stream frame: Broken pipe]
# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 524288
max total shared memory (kbytes) = 8388608
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages Limits --------
max queues system wide = 1652
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
# apt-cache policy zoneminder
zoneminder:
Installed: 1.27.99+1-trusty-SNAPSHOT2014080402
Candidate: 1.27.99+1-trusty-SNAPSHOT2014080402
Version table:
*** 1.27.99+1-trusty-SNAPSHOT2014080402 0
500 http://ppa.launchpad.net/iconnor/zonemi ... er/ubuntu/ trusty/main i386 Packages
100 /var/lib/dpkg/status
1.26.5-1ubuntu3 0
500 http://se.archive.ubuntu.com/ubuntu/ trusty/universe i386 Packages
# ipcs -l
zoneminder:
Version table:
1.26.5-1ubuntu3 0
