Hello - I have a Foscam webcam that I know works with Zoneminder. When I open a monitor I get the red screen with only the date and time on it. I have the software setup correctly, I believe. This is a relevant part of the zmc daemon log - seems it's getting the wrong format response from the camera:
08/25/14 13:55:58.663201 zmc_m2[13936].DB1-zm_monitor.cpp/2652 [Loaded monitor 2(kitty3), 1 zones]
08/25/14 13:55:58.663219 zmc_m2[13936].INF-zmc.cpp/195 [Starting Capture]
08/25/14 13:55:58.787211 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/119 [Connected to host, socket = 5]
08/25/14 13:55:58.787287 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/141 [Request sent]
08/25/14 13:55:58.802590 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/187 [Expecting 167 bytes]
08/25/14 13:55:58.802636 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/212 [Read 167 bytes]
08/25/14 13:55:58.802664 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/729 [Got status '200' (OK), http version 1.1]
08/25/14 13:55:58.802679 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/736 [Got connection 'close']
08/25/14 13:55:58.802688 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/742 [Got content length '2323']
08/25/14 13:55:58.802697 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/770 [Got content type 'text/html']
08/25/14 13:55:58.802754 zmc_m2[13936].ERR-zm_remote_camera_http.cpp/812 [Unrecognised content type 'text/html']
08/25/14 13:55:58.832359 zmc_m2[13936].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
08/25/14 13:55:58.849625 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/127 [Disconnected from host]
08/25/14 13:55:58.865907 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/119 [Connected to host, socket = 5]
08/25/14 13:55:58.865955 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/141 [Request sent]
08/25/14 13:55:58.886431 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/187 [Expecting 167 bytes]
08/25/14 13:55:58.886484 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/212 [Read 167 bytes]
08/25/14 13:55:58.886502 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/729 [Got status '200' (OK), http version 1.1]
08/25/14 13:55:58.886512 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/736 [Got connection 'close']
08/25/14 13:55:58.886521 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/742 [Got content length '2323']
08/25/14 13:55:58.886530 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/770 [Got content type 'text/html']
08/25/14 13:55:58.886540 zmc_m2[13936].ERR-zm_remote_camera_http.cpp/812 [Unrecognised content type 'text/html']
08/25/14 13:55:58.914323 zmc_m2[13936].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
08/25/14 13:55:58.931628 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/127 [Disconnected from host]
08/25/14 13:55:58.970086 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/119 [Connected to host, socket = 5]
08/25/14 13:55:58.970143 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/141 [Request sent]
08/25/14 13:55:59.017918 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/187 [Expecting 167 bytes]
08/25/14 13:55:59.017961 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/212 [Read 167 bytes]
08/25/14 13:55:59.017984 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/729 [Got status '200' (OK), http version 1.1]
08/25/14 13:55:59.017995 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/736 [Got connection 'close']
08/25/14 13:55:59.018004 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/742 [Got content length '2323']
08/25/14 13:55:59.018014 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/770 [Got content type 'text/html']
08/25/14 13:55:59.018024 zmc_m2[13936].ERR-zm_remote_camera_http.cpp/812 [Unrecognised content type 'text/html']
08/25/14 13:55:59.063940 zmc_m2[13936].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
08/25/14 13:55:59.098059 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/127 [Disconnected from host]
08/25/14 13:55:59.129801 zmc_m2[13936].DB3-zm_remote_camera_http.cpp/119 [Connected to host, socket = 5]
zmc daemon - [Unrecognised content type 'text/html']
Re: zmc daemon - [Unrecognised content type 'text/html']
Which Foscam camera? Makes a difference how you set it up and what stream you use...
Model # FI8918W
I have the same problem Camera beward bd4370 Can somebody help?
rtsp://login:password@<ip_camera>:554/h264
in log:
2014-08-26 11:24:33.540330 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 400: Bad Request]
2014-08-26 11:24:33.941825 zmc_m5[2802].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 404: Not Found]
2014-08-26 11:24:34.174036 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
2014-08-26 11:24:34.457554 zmc_m5[2802].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
2014-08-26 11:24:34.679345 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 400: Bad Request]
2014-08-26 11:24:34.951967 zmc_m5[2802].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 404: Not Found]
2014-08-26 11:24:35.165352 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
2014-08-26 11:24:35.349387 zmc_m5[2802].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
2014-08-26 11:24:35.662031 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 400: Bad Request]
2014-08-26 11:24:35.930842 zmc_m5[2802].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 404: Not Found]
2014-08-26 11:24:36.047141 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
2014-08-26 11:24:36.163642 zmc_m5[2802].ERR-zm_remote_camera_http.cpp/1110 [Unable to get response]
2014-08-26 11:24:36.389597 zmc_m1[2840].ERR-zm_remote_camera_http.cpp/726 [Invalid response status 400: Bad Request]
in log:
So I went back and re-installed Ubuntu server and zoneminder...and...I'm now able to get the video feeds! Now i just have to figure out how to implement the PTZ controls...
- knight-of-ni
Looks like instructions for your cmaera, inluding ptz control, are here:
http://www.zoneminder.com/wiki/index.php/Foscam_FI8918W
Note that there are already several Foscam ptz control scripts in zoneminder. If the script you end up using is different from any of these then consider generating a pull request on github to get it added into the source.
I used the newer Arun's script linked at the bottom to match my firmware - works great!
