Version 1.27.99.0.
Installed on Ubuntu 14...
Playing on Firefox 31
Servers are up and look running. Camera is green and Mod detect is capturing events...
But CAN NOT watch the video on Firefox 31.0.
I cant watch monitor stream... not events captured. Looks like zoneminder is watching them because has events captured and is green!!!
Any idea?
Servers are running. Cant watch video on Firefox.
- zm.png (186.9 KiB) Viewed 2422 times
Re: Servers are running. Cant watch video on Firefox.
You forgot to enable CGI in Apache2
CGI is not enabled in Ubuntu 14.04 by default. Enable it this way:
a2enmod cgi
Create a new user
adduser www-data video
Restart Apache
/etc/init.d/apache2 force-reload
Also in Firefox:
You will need to increase the number of allowed connections to use the montage view with more than a small number of cameras. Certain FireFox extensions such as FasterFox may also help to achieve the same result.
To resolve this situation, follow the instructions below:
Enter about:config in the address bar
scroll down to
browser.cache.check_doc_frequency 3
change the 3 to a 1
browser.cache.disk.enable True -> False
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
a2enmod cgi
Create a new user
Restart Apache
Also in Firefox:
scroll down to
change the 3 to a 1
That fixed it.
I didnt forget the CGI... I didnt know that CGI is off on Ubuntu 14.
Now we know!
Thank you so much.
