Trendnet TV-IP310PI
Posted: Sun Sep 21, 2014 5:28 pm
Hi all,
I have one stream problem with Trendnet TV-IP310PI (work fine with TV-IP262PI).
System: Debian 7.6
Zoneminder: 1.25.0-4
I use this options:
Source Type: Ffmpeg
Maximum FPS: Empty
Alarm Maximum FPS: Empty
Source Path: rtsp://USER:PASS@IPv4:554/streaming/channels/1
Source Colours: 24 bits
Capture Width (pixels): 1280
Capture Height (pixels): 720
Preserve Aspect Ratio: unckech
Orientation: Normal
Cam settings:
Video Encoding : H.264
Resolution : 1280*720P
Bitrate Type : Variable
Video Quality : Medium
Frame Rate : 8 frames per second
Max. Bitrate : 4096 Kbps
I Frame Interval : 60
Log Outputs:
2014-09-21 19:26:53.525588 web_php 5480 ERR socket_sendto( /tmp/zm/zms-145408s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2323
2014-09-21 19:26:47.506071 web_php 5480 ERR socket_sendto( /tmp/zm/zms-145408s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2323
2014-09-21 19:26:43.566782 zms 6239 ERR Terminating, last frame sent time 1411320403.066696 secs more than maximum of 10.000000 zm_monitor.cpp 3639
2014-09-21 19:22:29.167270 zmdc 5417 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2014-09-21 19:22:29.164483 zmc_m2 6237 FAT Unable to open input rtsp://USER:PASS@IPv4:554/streaming/channels/1 due to: Operation now in progress zm_ffmpeg_camera.cpp 95
Thx for your support
System: Debian 7.6
I use this options:
Source Type: Ffmpeg
Maximum FPS: Empty
Orientation: Normal
Cam settings:
Log Outputs:
