I install zoneminder on centos 6.5 and i can connect to zm console only from local PC.
How to connect from another PC on local network?
when I write the address "10.20.172.136/zm" in the browser, I get the message:
This page can’t be displayed
•Make sure the web address "ipadress" is correct.
•Look for the page with your search engine.
•Refresh the page in a few minutes.
I can't connect to zm console from another PC
- knight-of-ni
Re: I can't connect to zm console from another PC
Check your iptables firewall or just turn it off:
sudo service iptables stop
This ip does not seems a local ip address. Could you check that your local ip address is the one you're trying to access?marsimus wrote:Hello,
That IP should be local to his network. Anything on the 10.x.x.x network should be a local address since it isn't routable to or from the outside world. (RFC 1918)
Iptables stop helped. I can connect from my other PC to a local network. Thank you.
But still does not work HIKVISION network camera DS-2CD855F-E.
How to configure it correctly?
- knight-of-ni
Google is your friend.marsimus wrote:Iptables stop helped. I can connect from my other PC to a local network. Thank you.
https://www.google.com/search?client=ub ... +hikvision
Read through the various hits. Try all the settings you come across, even if your exact camera model is not mentioned.
Everything works, even with a 1920x1080 resolution. Thank you everyone.
