Page 1 of 1
I can't connect to zm console from another PC
Posted: Mon Sep 22, 2014 8:57 am
by marsimus
I install zoneminder on centos 6.5 and i can connect to zm console only from local PC.
How to connect from another PC on local network?
when I write the address "10.20.172.136/zm" in the browser, I get the message:
This page can’t be displayed
•Make sure the web address "ipadress" is correct.
•Look for the page with your search engine.
•Refresh the page in a few minutes.
Re: I can't connect to zm console from another PC
Posted: Mon Sep 22, 2014 2:25 pm
by knight-of-ni
Check your iptables firewall or just turn it off:
sudo service iptables stop
Posted: Tue Sep 23, 2014 6:28 am
by PacoLM
marsimus wrote:Hello,
This ip does not seems a local ip address. Could you check that your local ip address is the one you're trying to access?
Posted: Tue Sep 23, 2014 10:04 am
by BiloxiGeek
That IP should be local to his network. Anything on the 10.x.x.x network should be a local address since it isn't routable to or from the outside world. (RFC 1918)
Posted: Tue Sep 23, 2014 10:50 am
by marsimus
Iptables stop helped. I can connect from my other PC to a local network. Thank you.
But still does not work HIKVISION network camera DS-2CD855F-E.
How to configure it correctly?
Posted: Tue Sep 23, 2014 12:19 pm
by knight-of-ni
marsimus wrote:Iptables stop helped. I can connect from my other PC to a local network. Thank you.
Google is your friend.
https://www.google.com/search?client=ub ... +hikvision
Read through the various hits. Try all the settings you come across, even if your exact camera model is not mentioned.
Posted: Wed Sep 24, 2014 5:17 am
by marsimus
Everything works, even with a 1920x1080 resolution. Thank you everyone.
