I just installed the ZoneMinder server on CentOs 6 (which was real easy and straight forward, had it running in no-time!).
Now, I just created my first monitor, which is a remote source pointing to a Raspberry Pi (or actually, an Odroid-W, but it's basically the same as a RPi). When I connect with VLC to it I get a nice screen, unfortunatly, ZoneMinder shows me a scrambled screen. The hardware is not really relevant here I think, since it's a working network stream, but to be complete here, it's a Pi-NoIR camera, which on the Pi is streamed using "Motion" (can't post a URL here, search google for "foswiki motion").
The streaming server is configured to sent a 512x288, PAL, 15fps, msmpeg4 stream.
Attached is a screenshot of the scrambled result.
Anyone recognizes this??
Weird effect / no correct image
Re: Weird effect / no correct image
Hmm, the image wasn't attached to the post, retrying...
Ok, well image attachment isn't possible (maybe my user isn't on the forum long enough?)
Anyway, it looks a bit like this: http i.stack.imgur (dot) com/5NlDv (dot) jpg
Never mind, figured it out..
Motion was configured to rotate the image 90 degrees, therefore I had to put the height in the width field, and the width in the height field in ZM..
