No image in Monitor Zoneminder 1.27.0 and CentOS 6.5 X86_64
Tempesta48
Post by Tempesta48 »
Hi, I've been searching the forum, wiki and also Googled but couldn't not find the error in my installation.
I firstly started installing Zoneminder from source and compiling it but then found the zmrepo. I uninstalled the source compiled version and installed zoneminder-1.27.0-1.el6.x86_64 from zmrepo.
I keep getting this error:
Sep 27 19:40:15 server web_php[27904]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-923259s.sock ) failed: No such file or directory]
Sep 27 19:40:15 server web_php[4397]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-923259s.sock ) failed: No such file or directory - checkStreamForErrors()]
I've checked the ScriptAlias and it's OK. In the system logs I can see that the IP camera is working, eventhough in the web it's IP is in orange (not red or green), is that OK?
Sep 27 19:42:15 server zmc_m1[13492]: INF [Monitor-1: 1000 - Capturing at 22.73 fps]
I don't know if it's something related to the first installation of Zoneminder from source, but checking file /usr/share/zoneminder/www/ajax/stream.php I can see that the file /var/lib/zoneminder/sock/zms-947393w.sock is being created but not the same file ended with an "s" and can't find out why.
Can this error have something to do?
Sep 27 06:51:23 serverr zmwatch[18152]: ERR [Memory map file '/dev/shm/zm.mmap.1' should have been 896 but was instead 0]
I've also followed the instructions in this thread and in README.CentOS: http://www.zoneminder.com/forums/viewto ... =9&t=19119
Any help would be much appreciated!
Tempesta48
Re: No image in Monitor Zoneminder 1.27.0 and CentOS 6.5 X86
Cheking again the logs in Zoneminder and restarting the service, I've also found this 3 errors:
2014-09-27 19:58:50.148909	zmc_m1	13492	ERR	Unable to get response	/builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_remote_camera_http.cpp	1110
2014-09-27 19:58:50.106879	zmc_m1	13492	ERR	Unable to read subheader	/builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_remote_camera_http.cpp	938
2014-09-27 19:58:50.064892	zmc_m1	13492	ERR	Select error: Interrupted system call	/builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_remote_camera_http.cpp	162
Does this mean that the IP camera settings are not correct and that's why I can't see any image in the Monitor window? Or are these errors normal because I've just restarted the Zoneminder service?
The instructions from zmrepo are intended for those starting from a clean install, not a previous build from source.
Before you started using the zoneminder rpm, did you first do a "make uninstall" to remove the previous installation?
After installing the zoneminder rpm, did you start with a new database or are you trying to use the database that was created from the previous build from source?
