set default montage view ( or layout?) *SOLVED
Posted: Wed Oct 01, 2014 10:51 pm
I have been trying to figure out how to set the default montage view and have been unsuccessful.
I have searched thru the configuration settings, and have not found it yet.
I have also been searching thru the .css & .php files for the website and have not yet found it in there either.
I HAVE found how to add additional montage views.
Can anyone point me in the right direction for setting which view is the default selected one?
Thanks, Chris
** I finally found it: It is stored in a COOKIE on each individual PC ( zmMontageLayout ) - for some reason I had 2 cookies, and it was (of course ) using the older cookie, not the newer cookie which reflected the layout I wanted.
Thanks, Chris
