I'm using zoneminder for some time now and love it, but have recently bought some chinese (hi3518) IP cameras with 720 and 1080p but it only works partially with zoneminder.
I finally got it working with ffmpeg and added the rtsp:// url to the path, which works normally fine, modect detects motion and records.
Sometimes the image gets distorted on the bottom of the screen for unknown reasons. When this happens modect starts recording and I have a lot of events with distortion as motion.
Here is an image so you can see that I mean: abload.de/img/nph-zmsv9sfq.jpg (sorry the board didn't let me put in a clickable URL
I guess zoneminder gets some kind of hickups ? The log says:
sometimes: FAT Unable to open input rtsp://192.168.1.70/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream due to: Operation now in progress
very often: Shared data size conflict in shared_data for monitor HD2, expected 328, got 316
But that second error I know from my old zoneminder instance and since everything worked fine until the HD cams I ignored it.
Whats next to check? Would be awesome if I could go on using zoneminder since its a brilliant software.
Oh and computing power should not be the problem... it's running on an i5 and I tested it also on a 8-core xeon machine.
Thanks in advance!
