CMake Error at CMakeLists.txt:257
2Psycho
Post by 2Psycho »
Dear all,
During my initial upgrade session from V1.26.5 to 1.27.99 I came agros the following messages from Cmake:
CMake Error at CMakeLists.txt:257 (message):
  zm requires MySQL headers - check that MySQL development packages are
  installed
-- Configuring incomplete, errors occurred!
The "funny" part is that mysql-dev is installed.
I running ClearOs 6.5 (CentOs 6) any has/had the same issue?
So yes how can it be solved.
regards,
Enjoyment Matters
2Psycho
Re: CMake Error at CMakeLists.txt:257
Post by 2Psycho »
Problem solved by it self in release 1.28.0 :D
Enjoyment Matters
