Page 1 of 1
Timeline does not work ...
Posted: Thu Nov 06, 2014 4:55 pm
by augustynr
When I drag the mouse over the events on the timeline I expect the pics to show up above it, though I have a broken image. If I click on the event I get the event to play. If I click on Stills I get empty grid.
Any idea how to fix it?
Thanks,
Re: Timeline does not work ...
Posted: Thu Nov 06, 2014 9:56 pm
by bbunge
What OS are you using?
bb
Posted: Fri Nov 07, 2014 1:44 am
by augustynr
ubuntu 14.04
Posted: Fri Nov 07, 2014 1:15 pm
by knight-of-ni
Works fine here. As always, post any error messages you see from your log file.
Try the following.
Open the timeline, and select an event.
Right click where the image should be and copy the hyperlink to your clipboard.
Paste the hyperlink into a text editor and manually inspect it for correctness:
the folder it points to exists on your local disk (the path is relative your webroot)
file permissions are correct (must be writable by web account user)
the jpg file exists
Posted: Sat Nov 08, 2014 8:20 pm
by iconnor
I suspect an apache alias path misconfig or something. Do the event images work in non-timeline mode?
