Page 1 of 1
Avconv optimize video quality?
Posted: Thu Nov 13, 2014 11:42 am
by biologisch
Hi!
Is it possible to optimize the video output quality by using avconv?
With ffmpeg it was with the additional parameter -sameq
Thanks a lot. :mrgreen:
Re: Avconv optimize video quality?
Posted: Fri Nov 14, 2014 2:30 pm
by Mchammerdad
Do you mean the quality of the video for the live stream?
Or, perhaps you meant when you "export" events?
I've found the live stream quality when using mpeg (in the bandwidth settings) can be improved by upping your WEB_L_VIDEO_BITRATE (also in bandwidth settings) number. Mine is currently set at 1500000 and the video is fairly high quality.
Posted: Wed Jan 27, 2016 11:43 am
by biologisch
Hi again!
Long time ago but I mean the quality of the "export" events. The exported quality is very low. Is there an addition parameter needed for avconv?
Posted: Sat Jan 30, 2016 10:32 am
by SteveGilvarry
http://superuser.com/questions/478549/w ... me-quality
avconv and ffmpeg are both 3rd party tools, almost identical in many respects given avconv was a fork. But they both have their own documentation so would suggest having search and read of that.
Posted: Sat Jan 30, 2016 10:28 pm
by biologisch
I understand what you want to tell me: RTFM :wink:
Here the link witch helps me ->
http://superuser.com/questions/653126/r ... -in-output
So my FFMPEG_OUTPUT_OPTIONS (avconv) are:
-r 5 -b:v 1000K -q:v 1 -crf 23
Posted: Sun Jan 31, 2016 3:22 am
by SteveGilvarry
Looks like your RTFM'd your way through it. Good work.
