Unable to parse date string '-20 days'
fmoreira86
Post by fmoreira86 »
Hi good people,
I've my filter configured to delete everything that is 20 days old.
I'm getting: Unable to parse date string '-20 days'
Any help?
mikb
Re: Unable to parse date string '-20 days'
Post by mikb »
fmoreira86 wrote: I'm getting: Unable to parse date string '-20 days'
Try this in the boxes ... and [Date] [Less Than] [20 Days Ago]
Yes, "less than" -- "less than" mathematically is an older date. In spoken English you'd say "more than 20 days ago". However ... :)
I have had some problems with the filter not doing anything over -14 day or -14 days (you can use day or days). To get to your 20 days use "-2 week 6 day" or to do 21 days just use "-3 week".
By any chance are you using mocord?
I also have had problems with the purge when full by disk per cent not working when the disk (a new WD 1 TB disk) gets over 85%. Currently with 16 cameras on mocord and OPT_FAST_DELETE turned off I am managing to keep the disk between 79% and 80% with little impact on the load. The filter is deleting 96 events just about every hour which is what the recording is putting on the disk
