log error 255 with Axis 210A over mpeg4 or mjpeg/jpeg
VlaDeMaN
Post by VlaDeMaN »
hello everyone,
first time zm user here. i'm having an issue getting my cameras to work with the wiki's instructions. no matter what settings (mjpeg, jpeg, mpeg4) i try i get the same error. nothing works. clicking the probe link in the monitor setup give message "Unable to probe local cameras, status is '255'" used IE and chrome.
browser or vlc streaming works directly from the camera. prefer mpeg4 and i understand that's the only way i can also record audio from the cam.
on modect, an event appears every few minutes, but there is no data.
i've searched for a solution but got nothing. everything i found was about shared memory, but i'm not getting those errors. log attached. thanks!!!
forum wouldn't let me upload photos, nor post a link to imgur, so here is just the log output:
Date/Time
Component PID Level Message File Line
2014-11-15 17:45:02.717375 zma_m3 2533 INF STPcam01: 121 - Closing event 4, signal loss zm_monitor.cpp 1285
2014-11-15 17:45:02.618564 zma_m3 2533 WAR Signal: Lost zm_monitor.cpp 1282
2014-11-15 17:45:02.607580 zmdc 1624 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2014-11-15 17:45:02.544207 zma_m3 2533 INF STPcam01: 120 - Gone into alert state zm_monitor.cpp 1484
2014-11-15 17:45:02.509125 zmc_m3 2662 ERR Failed to pre-capture monitor 3 (0/1) zmc.cpp 260
2014-11-15 17:45:02.005791 zmc_m3 2664 ERR RTSP timed out zm_rtsp.cpp 574
2014-11-15 17:44:58.752323 zma_m3 2533 INF STPcam01: 110 - Opening new event 4, alarm start zm_monitor.cpp 1448
2014-11-15 17:44:58.635709 zma_m3 2533 INF STPcam01: 110 - Gone into alarm state zm_monitor.cpp 1428
2014-11-15 17:44:58.577526 zma_m3 2533 WAR Signal: Reacquired zm_monitor.cpp 1282
2014-11-15 17:44:57.340079 zmc_m3 2662 INF Starting Capture zmc.cpp 195
2014-11-15 17:44:57.173000 zmdc 2662 INF 'zmc -m 3' started at 14/11/15 17:44:57 zmdc.pl
2014-11-15 17:44:57.172960 zmdc 1624 INF 'zmc -m 3' starting at 14/11/15 17:44:57, pid = 2662 zmdc.pl
2014-11-15 17:44:57.094500 zmdc 1624 INF Starting pending process, zmc -m 3 zmdc.pl
2014-11-15 17:34:57.310826 zma_m3 2533 INF STPcam01: 095 - Closing event 3, signal loss zm_monitor.cpp 1285
2014-11-15 17:34:57.194799 zma_m3 2533 WAR Signal: Lost zm_monitor.cpp 1282
2014-11-15 17:34:57.175500 zmdc 1624 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2014-11-15 17:34:57.087043 zmc_m3 2621 ERR Failed to pre-capture monitor 3 (0/1) zmc.cpp 260
2014-11-15 17:34:56.584498 zmc_m3 2623 ERR RTSP timed out zm_rtsp.cpp 574
2014-11-15 17:34:54.503007 zma_m3 2533 INF STPcam01: 091 - Gone into alert state zm_monitor.cpp 1484
2014-11-15 17:34:54.145257 zma_m3 2533 INF STPcam01: 089 - Gone back into alarm state zm_monitor.cpp 1475
2014-11-15 17:34:53.819271 zma_m3 2533 INF STPcam01: 085 - Gone into alert state zm_monitor.cpp 1484
2014-11-15 17:34:53.714808 zma_m3 2533 INF STPcam01: 084 - Opening new event 3, alarm start zm_monitor.cpp 1448
2014-11-15 17:34:53.614902 zma_m3 2533 INF STPcam01: 084 - Gone into alarm state zm_monitor.cpp 1428
2014-11-15 17:34:53.563536 zma_m3 2533 WAR Signal: Reacquired zm_monitor.cpp 1282
2014-11-15 17:34:52.355746 zmc_m3 2621 INF Starting Capture zmc.cpp 195
2014-11-15 17:34:52.143120 zmdc 2621 INF 'zmc -m 3' started at 14/11/15 17:34:52 zmdc.pl
2014-11-15 17:34:52.143110 zmdc 1624 INF 'zmc -m 3' starting at 14/11/15 17:34:52, pid = 2621 zmdc.pl
2014-11-15 17:34:52.075860 zmdc 1624 INF Starting pending process, zmc -m 3 zmdc.pl
2014-11-15 17:25:46.559427 web_php 1823 FAT Unable to probe local cameras, status is '255' /usr/share/zoneminder/skins/classic/views/monitorprobe.php 40
2014-11-15 17:24:52.329817 zma_m3 2533 INF STPcam01: 069 - Closing event 2, signal loss zm_monitor.cpp 1285
2014-11-15 17:24:52.130648 zma_m3 2533 WAR Signal: Lost zm_monitor.cpp 1282
2014-11-15 17:24:52.095070 zmdc 1624 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2014-11-15 17:24:51.995552 zmc_m3 2589 ERR Failed to pre-capture monitor 3 (0/1) zmc.cpp 260
2014-11-15 17:24:51.492328 zmc_m3 2591 ERR RTSP timed out zm_rtsp.cpp 574
2014-11-15 17:24:48.698219 zma_m3 2533 INF STPcam01: 059 - Gone into alert state zm_monitor.cpp 1484
2014-11-15 17:24:48.593854 zma_m3 2533 INF STPcam01: 058 - Opening new event 2, alarm start zm_monitor.cpp 1448
2014-11-15 17:24:48.485615 zma_m3 2533 INF STPcam01: 058 - Gone into alarm state zm_monitor.cpp 1428
2014-11-15 17:24:48.432004 zma_m3 2533 WAR Signal: Reacquired zm_monitor.cpp 1282
2014-11-15 17:24:47.307873 zmc_m3 2589 INF Starting Capture zmc.cpp 195
2014-11-15 17:24:47.139180 zmdc 2589 INF 'zmc -m 3' started at 14/11/15 17:24:47 zmdc.pl
2014-11-15 17:24:47.139170 zmdc 1624 INF 'zmc -m 3' starting at 14/11/15 17:24:47, pid = 2589 zmdc.pl
2014-11-15 17:24:47.073150 zmdc 1624 INF Starting pending process, zmc -m 3
Re: log error 255 with Axis 210A over mpeg4 or mjpeg/jpeg
Did you try this: http://www.zoneminder.com/wiki/index.ph ... _streaming
What OS are you using?
