Edimax 3100p
Firmware Version : v2.0 PnV (Apr 7 2014 15:33:49)
MPEG-4 RTSP Path : ipcam.sdp
H.264 RTSP Path : ipcam_h264.sdp
RTSP Port :554
jpg stream path: /jpg/image.jpg <additional info, in case someone is trying out this cam>
Built from 1.28 master today on Deb wheezy 7.7.0
zmc_m3 ERR Received unexpected packet type 101, ignoring zm_rtp_ctrl.cpp 155
debug log:
http://pastebin.com/dfcZme3H
not sure if this helps but, installed: libavformat.so.53.21.1
knnniggett suggested poor rtp implementation by Edimax, perhaps edit line 155.
more info
zoneminder_1.28.0-wheezy_amd64.changes
zoneminder_1.28.0-wheezy_amd64.deb
zoneminder_1.28.0-wheezy.dsc
zoneminder_1.28.0-wheezy.tar.gz
zoneminder-dbg_1.28.0-wheezy_amd64.deb
libavc1394-0:amd64
libavcodec53:amd64
libavcodec54:amd64
libavdevice53:amd64
libavdevice54:amd64
libavfilter2:amd64
libavfilter3:amd64
libavformat53:amd64
libavformat54:amd64
libavutil51:amd64
Rec'vd unexpected packet type 101 - zm_rtp_ctrl.cpp/155
- knight-of-ni
Re: Rec'vd unexpected packet type 101 - zm_rtp_ctrl.cpp/155
Following our discussion on the zoneminder irc channel, I noticed that a type of 101 seems to be audio related. Try going through the camera webpage and see if you can turn off anything that mentions a microphone, an external speaker, audio, SIP, DTMF (not likely), etc.
Sadly there are no options to control audio interface on this cam. Thanks for the info though.
edit: I have to think edimax implementation of rtsp is very poor. Testing vlc and ffplay with known good stream (rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov) works as intended. Despite the packet 101 error it works very well in zoneminder , remote source type. CPU utilization is quite high, yet network traffic is very low.
Hi,attilahooper wrote:Edimax 3100p
RTSP Port :554
debug log:
more info
libavc1394-0:amd64
libavcodec53:amd64
libavcodec54:amd64
libavdevice53:amd64
libavdevice54:amd64
libavfilter2:amd64
libavfilter3:amd64
libavformat53:amd64
libavformat54:amd64
libavutil51:amd64
I'm still using ZM1.25 in my Debian Wheezy system. Do you have the step by step instructions to build ZM1.28 under Debian?
Thanks in advance,
PacoLM
Read and answered!attilahooper wrote:PM sent
I applied change suggested by knnniggett to line 155 in zm_rtp_ctrl.cpp and recompiled using instructions from README.md on github master branch (wheezy 7.7.0)
https://gist.github.com/knnniggett/b3281b4c18f2e0bcab4f
And log is clean.
// Change the following lines in zm_rtp_ctrl.cpp FROM:
Error( "Received unexpected packet type %d, ignoring", pt );
return( -1 );
// TO:
Debug( 5, "Received unexpected packet type %d, ignoring", pt);
break;
And log is clean.
- knight-of-ni
And you can view the stream in zoneminder?
We want to make sure it really works, and we didn't just silence the error.
yes, it streams very well as a remote source type.
Although I receive the following warning, motion capture still works properly: WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results
is that a user rights problem ?
I can't get ffplay or vlc to play /ipcam_h264 stream though. Which is why I want to try Ubuntu with libav that contains newer files from ffmpeg 2.5 branch. Ubuntu package appears (to me) to be very current, still trying to grasp specifics.
