I have 3 foscam FI8918w ip cameras that I can view directly from a browser without issue, but i can seem to get the preview working from within the zm console. I also cant review recorded footage from within the console. I checked the directory where recoreded jpegs are saved and they're all there.
The server is running on lubuntu 14.04
I have an almost identical setup running elsewhere where I dont have this issue
Any help apprecaited
Can't view ip cameras from zm console
Re: Can't view ip cameras from zm console
What does the log say is happening?
You have not provided enough information for anyone to help you at this point...
Cheers,
Jon
Cheers,
Jon
2015-01-08 16:32:29.839851 web_js 3477 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-01-08 16:31:08.535971 web_php 3477 ERR socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-01-08 16:30:48.526143 web_js 3477 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-01-08 16:30:48.363934 web_php 3477 ERR socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-01-08 16:30:27.111135 web_js 3477 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-01-08 16:30:26.651739 web_php 3097 ERR socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-01-08 16:30:24.343151 zma_m1 3454 INF Front: 3417 - Left alarm state (4) - 176(6) images zm_monitor.cpp 1499
2015-01-08 16:30:21.348558 zma_m1 3454 INF Front: 3392 - Gone into alert state zm_monitor.cpp 1492
2015-01-08 16:30:21.037350 zma_m1 3454 INF Front: 3390 - Gone back into alarm state zm_monitor.cpp 1483
2015-01-08 16:30:20.903487 zma_m1 3454 INF Front: 3389 - Gone into alert state zm_monitor.cpp 1492
2015-01-08 16:30:20.242891 zma_m1 3454 INF Front: 3385 - Gone into alarm state zm_monitor.cpp 1436
2015-01-08 16:30:06.676765 web_js 3097 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-01-08 16:30:06.559179 web_php 3097 ERR socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-01-08 16:30:00.283012 zma_m1 3454 INF Front: 3241 - Opening new event 4, section start zm_monitor.cpp 1397
2015-01-08 16:30:00.085361 zma_m1 3454 INF Front: 3241 - Closing event 3, section end zm_monitor.cpp 1377
2015-01-08 16:29:46.596764 web_js 3097 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-01-08 16:29:46.493468 web_php 3097 ERR socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-01-08 16:29:26.878399 zma_m1 3454 INF Front: 3000 - Processing at 6.90 fps zm_monitor.cpp 1150
2015-01-08 16:29:26.534667 web_js 3073 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2015-01-08 16:29:26.411029 web_php 3073 ERR socket_sendto( /var/run/zm/zms-109215s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2330
2015-01-08 16:29:25.703984 zmc_m1 3448 INF Front: 3000 - Capturing at 6.94 fps zm_monitor.cpp 2899
2015-01-08 16:29:19.595941 zma_m1 3454 INF Front: 2943 - Left alarm state (3) - 614(37) images zm_monitor.cpp 1499
2015-01-08 16:29:16.645654 zma_m1 3454 INF Front: 2918 - Gone into alert state zm_monitor.cpp 1492
2015-01-08 16:29:10.727301 zma_m1 3454 INF Front: 2882 - Gone into alarm state zm_monitor.cpp 1436
This means ZM does not get any images from your cameras. Please double check your settings, ZM is very picky about things as resolution and colormode (at least 1.25 is, I just realized that this is the forum for 1.28, maybe newer versions are able to autodetect image properties).
No, it is recording fine.
What is happening is that zms is not being run. ensure that cgi is enabled in apache (a2enmod cgi)
Thank you so much, this was the issueiconnor wrote:No, it is recording fine.
