I have a camera that oversees a very busy area. During the day I don't really care to have it record any activity, but during the evening I'd like to enable the motion detection and have it record. So during the day I'd like to have the camera on Monitor function and at night switch it to Modect. Is there a way to schedule this on ZM?
Are there command line statement that you can send to ZM to have it switch functions for a specific camera? If so perhaps I can setup a cron job that would the script at the times that I need to make the change. Love to hear input from other and how they've tackled this. Thx.
Scheduling Modect?
Re: Scheduling Modect?
I'll add an issue to github about it, but I suspect it will be a while before it is supported unnless someone throws money at it.
For now, what I would do is use cron to run a script that updates the Function column of the Monitors table and then restarts zmc for that monitor.
iconnor;iconnor wrote:I'll add an issue to github about it, but I suspect it will be a while before it is supported unnless someone throws money at it.
I appreciate you helping me out with my request. I did manage to get my script to update the database, however I'm not sure how to restart zmc for the monitor.
zmdc.pl restart zmc -m 1
to restart monitor 1
- knight-of-ni
This feature is already supported and is documented in the FAQ:
http://www.zoneminder.com/wiki/index.ph ... or_week.3F
Once you have your states defined then call them from cron.
Is't it easier to set it up with Scheduling as described in the FAQ's rather than messing with writes to the db and restarts.
FAQ How can I get ZM to do different things at different times of day or week?
Using Ex.
0 8 * * * root /usr/local/bin/zmpkg.pl Daytime
0 20 * * * root /usr/local/bin/zmpkg.pl Nighttime
Jimmy
Using Ex.
Jimmy
- knight-of-ni
There is an echo in here.
What a difference an 13 min coffee break makes
