Kodicom 8800R settings for Ubuntu 14.04.1LTS and ZM 1.28
gavinp
Post by gavinp »
Just in case it helps anyone: to get the card working with Ubuntu 14.04.1LTS and Zoneminder 1.28 you need the following settings in the /etc/modprobe.d/bttv.conf file:
alias char-major-81 bttv
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=1 full_luma_range=1 coring=1
Hope this helps.
Gavin
Re: Kodicom 8800R settings for Ubuntu 14.04.1LTS and ZM 1.28
The setting for this card are already documented in the wiki:
http://www.zoneminder.com/wiki/index.php/Kodicom_8800
If there is anything that is inaccurate or out of date then you may consider updating that page.
