Verint S1708e RTP (Not RTSP!) over UDP - help!
Posted: Sun Jan 11, 2015 6:22 pm
Hi there.
Been working on documenting the generally closed and lightly documented Verint Nextiva S1708E network video digitizer to use with ZoneMinder. I've been able to configure the device on the network and even use rtpbreak/avconv (ffmpeg) to make the data usable and viewable in the two-step process that's not directly
Now, this device sends rtp packets over a particular UDP port to a destination IP address, ideally the ZoneMinder server. This is RTP and not RTSP, so please be mindful that it's a different but related protocol.
What would I need to do to get ZM 1.27+ working with these RTP streams?
I've collected together various bits on a wiki in case anyone wants to take a look but sadly my link in this message to my wiki 'looks too spammy' according to the Forum bot so PM me and I will send the wiki URL out.
If you are in the UK or greater EU and want to extend functionality directly into ZoneMinder, I could probably mail you one of these network digitizers.
Your help and insight would be appreciated! Thanks!
