Upgrade to 1.28
ositstomc
Upgrade to 1.28
Post by ositstomc »
Hi
I am running Ubuntu 14.04 and would like to upgrade my Zone minder from 1.27 to 1.28, I have add ppa:iconnor/zoneminder to my sources but each time I try to apt-get install Zoneminder it keeps downloading 1.26.5-1ubuntu3 version, can anyone explain why it doesnt fetch the latest ver?
Thanks in advance
TomC
Re: Upgrade to 1.28
Check this out:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
If you had the PPA installed to do 1.27 you may have to remove it and load it again:
http://ask.xmodulo.com/how-to-remove-pp ... buntu.html
Re: Upgrade to 1.28
It may be that I simply havn't made a package for 14.04 yet. I will look into it today.
Re: Upgrade to 1.28
No, there is definitely a package there. try re-adding the ppa.
PacoLM
Re: Upgrade to 1.28
Post by PacoLM »
iconnor wrote:It may be that I simply havn't made a package for 14.04 yet. I will look into it today.
Hi Connor,
Could you please add a Debian Wheezy package? It could be really useful as there are many Debian users here too!
Thanks in advance and keep the good work!
PacoLM
ositstomc
Re: Upgrade to 1.28
Post by ositstomc »
Hi
I have tried to remove the PPA using ppa-purge as well as the add-apt-repository --remove but it does not seem to remove the file iconnor-zoneminder-trusty.list stays in the sources.list.d folder which is weird?
Is it enough just to delete this file which I have done and then re-add the PPA, as this has made no difference?
Thanks Again
TomC
Re: Upgrade to 1.28
Yes that will do it.
ositstomc
Re: Upgrade to 1.28
Post by ositstomc »
Anything else I can try, I have removed the PPA and re-added and then tried to upgrade but its not getting past 1.26.5?
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.1 LTS"
Many thanks
TomC
PacoLM
Re: Upgrade to 1.28
Post by PacoLM »
Did you run apt-get update before apt-get upgrade?
