hi there
I have 2 cameras on ZoneMinder
- 1 goes with image snapshots (so 1.5fps) and is ok
- the other, I have 2 streams (720p stream and a CIF-stream)
I do motion detection on the CIF (2fps) and record (nodect) the 720p (limit to 8fps) stream by using a trigger.
It's been working ok, but lately I have this:
the CIF stream is OK, but the 720p stream is missing a lot
unfortunately I cant post links or images to show you anyone know how to solve this?
When I look via the webpage of the camera there the 720p stream look ok.
ZoneMinder is accessing this cam (both streams) via FFMpeg rtsp
images not ok
Re: images not ok
Under the Source Tab of the camera change Remote Method to RTP/RTSP, this uses TCP and stops packet loss on ffmpeg UDP connections.
