Shared data not initialised by capture daemon
freak
Post by freak »
Using 1.28.1 with mapped memory...
Whenever I view a monitor I get the following error. The monitor appears to work just fine however so I'm not sure why I get this error. Any insight?
2015-02-25 10:49:24.321631	zms	32767	WAR	Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor cam01-I-receptionist	zm_monitor.cpp	426
Re: Shared data not initialised by capture daemon
The message you have posted is not an error message.
WAR = warning
WAR != error
The message is merely a nusciance and will get fixed eventually. Since it is not hurting anything just ignore it.
freak
Post by freak »
Ok thanks! I thought it meant that a WAR was going on in my processors. :D
