I want to set a minimum alarm duration for alarms. When i set modetect with standard buffer value, I get a lot of events around 2 seconds by event for monitors at 25 fps...
I read that i need to set post event image count buffer in frames but not lower than the image buffer zier setting..
If a want to get 10 sec at 30fps, i have to set image buffer size at 300 ans post event image count at 300...
I have now one of my monitors wich has errors
Shared data not initialised by capture daemon for monitor Sous-Sol /usr/src/ZoneMinder-1.28.1/src/zm_monitor.cpp line 421
zma -m 10' exited abnormally, exit status 255 zmdc.pl
are thoses values too high and maybe a memory issue?
thanks
Simon
[SOLVED] Minimum alarm duration
Re: Minimum alarm duration
This might not be the correct answer however I always set my "Image Buffer Size" to a little
more than double the "Pre Event Image Count". After doing this you might have to restart
Zoneminder. The Monitor resolution makes a difference in available memory. Most of my
installs have 8 GB, with a min' of 4 GB on a couple, some have 16.
Be aware that the frame rate is not always perfect. After you get your buffers
going check the events.
I set buffer to 200,
pre event to 25
post event to 200
no more problem with zma
Simon
pre event to 25
post event to 200
Simon
Re: [SOLVED] Minimum alarm duration
In another thread, kkroft suggested using "Alarm Frame Count" (its inside Source->Buffers). That is working very well for me to eliminate spurious alarms.
My guess is if you want to do it by "minimum time" then time = frame count * fps that the camera is streaming to ZM
sime wrote:I want to set a minimum alarm duration for alarms. When i set modetect with standard buffer value, I get a lot of events around 2 seconds by event for monitors at 25 fps...
thanks
Simon
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
I don't want to eliminate spurious alarms. I wanted longer alarm events... my spurious alarms are removed by filter
Simon
Simon
